Sponsored by: Auxito
What's this hose?
Old May 8, 2003 | 08:31 PM
rc100's Avatar
rc100
What's this hose?
New 03 E250, 4.6 auto. There is a rubber hose attached to the side of the trans. fill tube under hood. It has a schrader valve in the end of it looks like it belongs on a tire with a green screw cap over the end of the hose. Can't figure what would require pressure or is it for testing something?
Old May 9, 2003 | 12:12 AM
Racerguy's Avatar
Racerguy
What's this hose?
Hi rc100 and welcome to FTE
It sounds like what you're describing is the EVAP test port.
A dealer uses it to check for leaks in the EVAP system. You can pressurize the fuel/EVAP system with metered nitrogen, or smoke from a smoke machine, to find leaks.
