Grrrrrr...no start, no codes, checked usual suspects
Old 07-04-2012, 01:20 PM
Tailgate77478's Avatar
Tailgate77478
Tailgate77478 is offline
Well, I'm a bit stumped. "HIS" truck won't start. Was working just fine, it sat for about 4 days, and then, won't start. It cranks, but sounds like it's starved for fuel. No check engine light on, WTS goes out like normal. Hooked up AE and there are no codes, except when I do a KOEO test, I get a P0605 (see #7 below). So here's what I've checked:
1. Fuel pump seems to be working fine. When I key on, the fuel pressure builds up to 80 psi (pre-filter port in the fuel bowl).
2. ICP sensor had no oil in the plug, but disconnected anyway and attempted to start, didn't work.
3. IPR nut is on securely (wasn't loose).
4. Oil is full, I even added oil into the HPOP reservoir "just in case" the LPOP was leaking down.
5. Batteries are fully charged, ohming at 14.26 each
6. I suspected it may have been the starter, which had 211,000 miles on it, so I replaced it. Not the problem (although the new one is really cranking strong!!!)
7. Due to the P0605 code, I pulled my chip out. Still no start.
8. CPS replaced with a spare, no start.
9. Because it's an Excursion, it has a GPCM instead of a GPR. However, the GPCM usually would throw codes that AE sees when acting up, and I have no codes. The GPCM is about 8 months old, if not newer.
10. Glow plugs are all 6 months old, with new UVCHs.
11. Fuel cut-off switch is not the problem.
I may have checked a few other things, but this is all I can remember at present.
Any ideas?
Old 07-04-2012, 02:43 PM
F350-6's Avatar
F350-6
F350-6 is offline
How long are you cranking each time? Cranking for 20 seconds will sometimes throw a code.
Have you monitored any live data while cranking? Battery voltage, ICP pis, IPR %?
Old 07-04-2012, 02:54 PM
twg1966's Avatar
twg1966
twg1966 is offline
Trying to Gain Knowledge
I had a similar problem about a year and a half ago. No clue as to why it wouldn't start. I would turn it over and over and over and no luck. The first thing I tried was a review of all the fuses. I pulled and reseated the one for the fuel bowl heater, along with most the others, and tried the ignition and it turned over and ran strong. Not that this is the issue, but don't rule out a simple check of the fuses.
Old 07-04-2012, 03:31 PM
Tailgate77478
Chris:
No, I have not. Maybe I will do that. But cranking for 20 secs? Won't that burn up the starter?
Twg1966:
Yeah, I thought about that...it's fuse 30. Usually when there's a fuel bowl heater issue, the WTS light doesn't come on. But what the heck, I'll pull that fuse and look at it. Maybe pull the heater wire. I *think* it's disconnected anyway, but I will double-check. Sure would be a quick easy fix.
Old 07-04-2012, 03:36 PM
twg1966's Avatar
twg1966
twg1966 is offline
It is only a thought. Good luck with finding the fix. Hopefully it is a simple issue and not something more complicated.
Ted
Old 07-04-2012, 04:16 PM
Tailgate77478
Ted
Let's hope so!!! Simple problems are usually the hardest to troubleshoot.
I checked, and I already had the fuel heater disconnected. I pulled the fuse and it *looked* good. Reinserted. Haven't tried cranking it, as I have a trickle-charger on there juicing up the batteries after all this cranking. Was only at 13.5, but figure I'll get it back up to 14+ before cranking again.
Old 07-04-2012, 04:23 PM
F350-6's Avatar
F350-6
F350-6 is offline
Originally Posted by Tailgate77478
Chris:
No, just let the starter cool for two minutes before you try and crank again.
Old 07-04-2012, 04:24 PM
woodnthings's Avatar
woodnthings
woodnthings is offline
I would do what Chris suggested and monitor ICP, IPR-DC and battery voltage while cranking. I am thinking it could be a stuck IPR and you are not building ICP.
Old 07-05-2012, 07:50 AM
roadrnnr's Avatar
roadrnnr
roadrnnr is offline
Do you get an electrical clicking sound? Like a relay hasn't closed o something? I get that since I installed my Stancor. It just tries and tries, no codes, no smoke. Batteries are fully charged etc too.
Old 07-05-2012, 02:50 PM
JMalmy21..00/7.3's Avatar
JMalmy21..00/7.3
JMalmy21..00/7.3 is offline
Not trying to hi-jack someones thread but i am dealing w the same problems right now and i AM hearing the veru quick clicking sound. Now my truck is just dead. Nothing, not even a crank or any dash lights or radio or air.....nothing
Old 07-05-2012, 03:17 PM
fordpride's Avatar
fordpride
fordpride is offline
Requirements to start a 7.3
Vehicle Power : *10.5v ****************************************Vehicle Power : 10.5v
RPM Signal : 100rpm ******************************************RPM Signal : 100rpm
Inj. Cntrl Press. (ICP) : *0.85v (about 500psi) *****Inj. Cntrl Press. (ICP) : 0.85v (about 500psi)
Fuel Pulse Width : *1 to 6 milliseconds ***************Fuel Pulse Width : *0.5 to 2 milliseconds *
Old 07-05-2012, 05:20 PM
MR5x5's Avatar
MR5x5
MR5x5 is offline
Getting lots of white smoke out the pipe? You should be if your injectors are firing...
Old 07-06-2012, 08:33 AM
JMalmy21..00/7.3
As far as i can tell, i dont see any white smoke when i start.. never have lol
Old 07-06-2012, 10:08 AM
MR5x5's Avatar
MR5x5
MR5x5 is offline
White smoke is unburnt fuel - when injectors are firing and the engine is NOT starting. And we're not talking about a little white smoke....
No crank - clicking - best take a look at your batteries.
Old 07-06-2012, 11:06 AM
novice psd's Avatar
novice psd
novice psd is offline
I agree with the look at you batteries. If they need replaced, always replace both, never just one.
Quick Reply: Grrrrrr...no start, no codes, checked usual suspects
