injection contral pressure
Old Jul 4, 2012 | 10:43 AM
caleb 99's Avatar
caleb 99
what should the injection control pressure be at idle and at wide open throttle thanks
Old Jul 4, 2012 | 10:47 AM
444dieselrod's Avatar
444dieselrod
600-800PSI at idle, 3000PSI under full load if you got a good pump.
Diesel Rod
Old Jul 4, 2012 | 10:50 AM
caleb 99's Avatar
caleb 99
thanks mine only has 400 to 500 psi i at idle could that cause a miss and loss of power and at wot i am getting 1200 to 1600 psi
Old Jul 4, 2012 | 11:15 AM
444dieselrod
yep, those are to low, are you reading them with a mechanical gauge?
It may be the IPR sticking, which they are known to do. its under the HPOP on the drivers side of the motor you can take it out and clean it, see if that brings the numbers up, otherwise its possible you have some blown injector O-rings and they are causing that cylinder to not fire causing the miss and low oil pressure, time to pull the valve covers and see which cyclinders arent working.
A trick to do first is let the engine cool, then fire it up and feel every exhaust port, the ones that stay cool are not firing, that will help speed up the process of figuring out which cylinders are missing.
once the valve covers are off fire the engine and look for oil squirting out the small square defelctor on the side of the injector, no oil, no worky. pull that injector out and look for cut O-rings.
Diesel Rod
Old Jul 4, 2012 | 06:21 PM
F350-6's Avatar
F350-6
If this is your 99, 460 - 550 is normal at idle. 1,200 - 1,600 at WOT is a problem regardless of what year motor you have. Is there any signs of oil in your fuel filter bowl?
Old Jul 4, 2012 | 06:31 PM
fordpride's Avatar
fordpride
If its a OBS Cali model the ICP at idle will be low cause they has split shot injectors
Old Jul 6, 2012 | 10:11 PM
caleb 99's Avatar
caleb 99
hey well thanks for letting me know about that IPR and no their is no oil in the fuel bowl and yea it may be time to go under the valve covers but let me throw this out thier could it be the IDM going bad
Old Jul 6, 2012 | 10:44 PM
chicagodragon's Avatar
chicagodragon
Is it hard to start,also?
Old Jul 6, 2012 | 11:00 PM
nomad221's Avatar
nomad221
Is your truck throwing any codes ?
dchamberlain
Feb 12, 2016 05:08 PM
Bubbacat
Aug 27, 2015 07:35 AM
sportsdad
13
Jun 8, 2014 05:06 AM
Hunter40
Mar 17, 2013 09:06 AM
wildhare
Apr 27, 2008 10:55 PM
