I have to many wires going to my battery terminal so what I was told I needed to do was put a fuse box or something next to the battery to tie all these accessory wires into. Anyone have a suggestion on what kinda fuse box I should use and how do I tie a wire into it?
I suggest ya order catalogs from Summit and Jeg's. They list a zillion parts from the aftermarket and provide a pretty good picture of what is available.
Painless Wiring carries a few different auxiliary fuse boxes. One is the CirKitBoss which, IIRC, has up to like seven circuits - some hot at all times and some only with the ignition hot.
I had the very same problem and got an add-on fuse block from one of the local auto parts stores. I mounted it near the starter solenoid. Mine has 6 terminals, and is fed from the hot side of the solenoid. Less than $10 IIRC.
Heres what I did. Main painless fuse block. Accessory fuse block, and relays on top. Of course this is in the cab, but you can use some sort of an accessory fuse block in the engine bay.
In my engine compartment I have a 2 stud terminal block that I run a 8gauge wire to each side. I use this to feed the main power to any accessories. and then theyre fused in the cab
Thought I had some pics, but I guess I dont. Summit has everything your looking for.
Wow, talk about options. Thanks everyone for you ideas. I think i will go with dynamic's idea. I really like the look of that box. I will probably put on under the hood for stuff that i dont need to turn on with the ignition and ill put the smaller version of that box in the cab for stuff i want to turn on with the ignition
Look at how the accessory wires attach to it. One has them screw on the front side. And one has them screw to the backside and theyre hidden. I used the backside one on my dads boat.
Yea i just looked again. Both those i posted above have screws on the front side.... And the one has an additional 12 screws which is whats confusing me.
