The low side is the line coming from the condenser to the dryer. Passenger side
the lines running to or from the condenser are high side lines. one carries high pressure gas (to be condensed) the other line carries high pressure liquid (condensed refrigerant)
How do i know where the low side valve is on an 88.
just hit me... is this an r12 ac system? being an 88 it might be and i would inquire about as to if its ever been converted to 134a. the low side valve i think is right on the compressor. it might even have an H and an L cast into the head where the service valves thread in to it.
1988 originally is R12. I converted my 87 to R134a without issue. The low side is where you will charge the system. It's located on the passenger side off the dryer. You want to change any leaky o-rings first then draw vacuum on the system for atleast 1/2 an hour to boil the moisture out.
I am replacing both lines,as well as the dryer and orifice tube. Then I'll put on the vac pump and check for leaks. And I will be dropping some $$to fix, but a shop would kill me on parts markup and labor, an besides the spirit of this forum is diy, right? I have the fuel line disconnect tools, so getting the liquid line off looks to be the one sticky spot. And having AC in my rig would make it really njce! Thank you, C
