Brakes- having to pump?
Old Jul 3, 2012 | 08:27 AM
alvald83's Avatar
alvald83
My brakes have felt the same since I've had the truck. But lately, I figured out that if I pump them a few times before the.re needed I have much better brakes. Which leads me to believe that I've got brake issues. Would it be the booster or air in the lines. I don't see any leaks anywhere and I replaced the master cylinder about 2 months ago. I did bench bleed it when I installed it. Since I didn't step on the pedal while replaceing the mc, I didn't bleed the brakes. I thought it was ok since it felt the same as before.
At this point the truck stops pretty good, but stops much better when I pump the brakes. Where do I start?
Old Jul 3, 2012 | 08:45 AM
vwfreak's Avatar
vwfreak
Bleed 'em.
Any time you swap a major component like that you have to ensure no air is in the lines. Start at the wheel furthest away (passenger rear) then work you way towards the MC. MAKE CERTAIN you check the level of fluid in the reservoir every few pumps and add as needed or you will create work for yourself by pumping air in. Get a buddy to help and make sure they understand to only push the pedal and release it when you tell them (i.e. coordinate with opening and closing of the bleeder valve) so you don't suck air in at the wheel cylinders.
Old Jul 3, 2012 | 11:15 AM
elgemcdlf's Avatar
elgemcdlf
I like gravity bleed. Open the bleeder of the wheel farthest away and let it flow until new fresh fluid runs out. Then work your way back towards the master farthest wheel to nearest wheel. Also check adjustment of the rears if a disc/drum truck. If 4 wheel drum adjust all the wheels.
Old Jul 3, 2012 | 11:59 AM
MIKES 68 F100's Avatar
MIKES 68 F100
bleed them , even though you didn't step on pedal air still got in when you opened system . i prefer power bleeder (hand style )
Old Jul 3, 2012 | 01:10 PM
Alex from GA's Avatar
Alex from GA
If they're out of adjustment they'll require a pump or two for maximum pedal. Get the air out first.
Don Vito
16
Oct 31, 2016 10:41 AM
jebby69
Jun 3, 2010 04:01 PM
HILLBILLY BOB
Jun 5, 2009 02:10 PM
willass
Mar 8, 2009 08:01 AM
blueeyemag
1983 - 2012 Ranger & B-Series
May 7, 2007 10:10 PM
