360 Rebuild Help
Old Jul 4, 2012 | 05:08 PM
MechaNick702's Avatar
MechaNick702
I'm going to make some calls now. What's really stopping me are the unknown issues that come with purchasing from ebay and craigslist.
Old Jul 4, 2012 | 11:27 PM
orich's Avatar
orich
Don't know the area where you live but you should also search the loco junk yards to see what's out their lurking in the back rows the you may not seen yet. Well today like their's 3 390's listed in C/L in and around my area. Its faster to use the search box at c/L then going through each ad one by one looking. Keep in mind of what your going to use your truck for, towing, cruising town & some back streets racing your friends. Or a daily driver. Gas is not cheap any more to run these old beast. When your getting 8-13 mpg for most of are trucks with out racing around. So don't get crazy with big carbs & wild cams unless it's a weekend race-cruiser. And it hurts the wallet when you have to run the highest octane gas you can find when you've pumped the motor up so high that that's all it will run on now. Just some mistake some guy make while building these old motors up.. But the more research you do the more you'll end up with what's best for you and be happy with it..
orich
Old Jul 5, 2012 | 02:33 PM
MechaNick702
I live in the Las Vegas area if anyone can help me out. I want to use the truck as a daily driver and for a weekend fun loving trail truck.
Old Jul 5, 2012 | 02:58 PM
yellow truck's Avatar
yellow truck
If you do a rebuild, look up the oiling mods for the FE on this site and get them done.
If you do the 360 you might as well get a crank and make it a 390. It is not just 30 cubic inches, it is compression and stroke.
Old Jul 5, 2012 | 04:35 PM
65f100CoryE.'s Avatar
65f100CoryE.
best is to remove engine yourself and carefully dismantle everything. and if you have access to reasonably accurate measuring stuff you can measure things yourself and get a base line to know if your being screwed over.
The less time the machine shop / mechanic has your motor / truck the cheaper things end up. if items are still within reasonable tollerances many times a freshen up rings, bearings, Tchain, a cam upgrade and you can get some nice power for 1000-1500 bux. even with a 360. but best is to swap the 390 crank and rods in but use the pistons that come with the 360 (they will likley be stamped 390 4V) and will be flat tops giving you that stroke Paul is talking about which nets 10+:1 compression which makes pretty nasty bottom end torque in a hurry.
Old Jul 5, 2012 | 07:14 PM
MechaNick702
So you're saying that even if I have a 360 change it up to a 390? Is it an expensive process?
MechaNick702
Also is there anyway for me to check and see if my block is cracked?
Old Jul 5, 2012 | 09:22 PM
orich's Avatar
orich
Not very often some will have a cracked block unless your in the freezing cold country. Or over heating or adding cold water while is hot. but mostly will damage the heads/gasket. Water in oil/oil in water. A shop can magnaflux
it for cracks when its cleaned and bare block.. orich
Old Jul 5, 2012 | 09:33 PM
HIO Silver's Avatar
HIO Silver
If you insist, here is a product to do so: https://www.pegasusautoracing.com/gr...upID=CRACKTEST
However, it's not really worth your time (and apparently budget). Let the pros magnaflux it... it's worth it IMO.
Old Jul 6, 2012 | 12:44 AM
MechaNick702
Sounds good to me. Thanks for all the insights.
Ok on of my last questions: What's the main difference between a 360 and 390?
Old Jul 6, 2012 | 12:46 AM
MechaNick702
Old Jul 6, 2012 | 12:54 AM
smokenchoken's Avatar
smokenchoken
difference between 360 and 390
stroke is longer in 390 the 360 uses a 352s crank so its just basically a de-stroked 390 .....390 has higher compression.... according to the numbers at the time with just 2 bbls 360s made 215 hp and 390s made 255 hp real numbers are a little higher than that
Old Jul 6, 2012 | 05:09 PM
  #28
MechaNick702
So switching out my crankshaft ups a 360 to a 390?
Old Jul 6, 2012 | 05:21 PM
  #29
HIO Silver's Avatar
HIO Silver
Crank and rods.
Old Jul 7, 2012 | 12:48 PM
  #30
MechaNick702
sweet I thought there was more to it than that.
I think I'm going to tear down the block myself, have it machined, then rebuild it myself.
