6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
exhaust filter cleaning
Old Jul 2, 2012 | 09:24 AM
dougie brault's Avatar
dougie brault
wat is that on my 2008SD 6.4
Old Jul 2, 2012 | 09:44 AM
thomabb's Avatar
thomabb
Ask this down in the 6.4 forum, they will be able to give you a more detailed answer.
Basically your truck is running the temp up in the exhaust to burn the carbon out of the filter.
Old Jul 2, 2012 | 09:45 AM
smokewagun's Avatar
smokewagun
Read your owners manual. There is more than an explanation there.
Old Jul 2, 2012 | 01:41 PM
powerstroke72's Avatar
powerstroke72
Moved to the 6.4L Power Stroke Diesel forum.
Old Jul 2, 2012 | 06:19 PM
senix's Avatar
senix
Exhaust cleaning...or more commonly called regen or the proper term (shows on your dash briefing) "cleaning exhaust filter".
This is the cleaning of the diesel particulate filter or DPF. The DPF is designed to catch the soot from your exhaust and trap it. Once the DPF is full of soot then a regen is triggered to burn off the soot.
The soot is burned off during this regen by a process of injecting raw fuel on the exhaust stroke. This fuel is sent down the exhaust to the dpf where it superheats the dpf and burns the soot.
Normal regens are considered anywhere from a 100 miles to as much as 630 between intervals. Towing will drastically change the interval as well as fuel quality and your actual driving conditions.
Old Jul 2, 2012 | 07:03 PM
RM2738's Avatar
RM2738
It means: Poor mileage, poor performance and engine life decreasing.
Welcome to FTE!
slinky_70
6.7L Power Stroke Diesel
29
Jul 6, 2021 04:49 PM
milkweed.gardener
Jul 23, 2018 10:11 PM
BigBri BigBri
Jan 9, 2011 04:46 PM
Percys Armory
Nov 9, 2010 09:08 AM
