tranny problems
Old May 8, 2003 | 03:05 PM
aliensmurf's Avatar
aliensmurf
tranny problems
I have a 63 f-100 with a freshly rebuilt 292 and a fordomatic 3 speed tranny. My problem is the tranny leaks fluid after it cools off. There is a vent ( i assume it's a vent) on the back passenger side just above the pan. that is where i lose my fluid. I took it to the car wash and cleaned everything underneath the truck and drove it home, parked over a white sheet, no leaks all day. i woke up this morning to find a small puddle of tranny fluid under the truck. Can someone help me?
Old May 8, 2003 | 03:14 PM
44dwarf's Avatar
44dwarf
tranny problems
Sounds like converter drain back. If you start it and quickly put it in gear does it try to move or does it take a few seconds to go clunk and move?
The best guy i know for auto trany stuff that happy to talk to you is Burt Brown at http://www.burtbrownracingtrans.com/
44dwarf
Old May 10, 2003 | 11:12 PM
aliensmurf's Avatar
aliensmurf
tranny problems
the guy that i had put in the tranny cooler switched one of the tranny lines with a cooler line, so the fluid was going in the vent and out of the cooler return. thanks for the help anyway.
