Sponsored by: Real Truck
learning my truck thread
Old Jul 4, 2012 | 12:58 PM
bertF250's Avatar
bertF250
haha I'm not a "meter guy" myself, lets wait for others to reply and see what they say.
Old Jul 4, 2012 | 04:43 PM
gfl's Avatar
gfl
If the PO had a different head unit, and returned it to stock, there could be some cut and spliced wiring behind the radio. I've used cut clothes hanger in the 4 holes of the stock head unit to release them,, but ymmv.
Old Jul 5, 2012 | 02:06 PM
airmark's Avatar
airmark
thanks for the coat hanger tip. i havent tried the speaker test yet im still thinking i should be able to hear something from drivers side if blown.i think ill pull the deck and check that out first.now to find a old school wire coat hanger.the wife uses the plastic ones.
Old Jul 5, 2012 | 03:47 PM
FordGuy85's Avatar
FordGuy85
Originally Posted by 2000silverbullet
My wife laughs when I bust this hat out, but this thing is the best, hands free lighting (bought mine at Lowe's):
http://www.amazon.com/Panther-Vision.../dp/B0051A6ZWG
I usually use a strap type headlamp for everything and I mean everthing. It's bright as heck and your head wont get sweaty.
Old Jul 5, 2012 | 04:08 PM
2000silverbullet's Avatar
2000silverbullet
I've also had good luck with bailing wire and finishing nails for the head unit removal. They're not ideal, but can work in a pinch. Just gotta get the right diameter (wire hangers work perfectly as mentioned). You can also get the head unit removal tool and some auto parts store, usually pretty cheap.
I got a few of the hats now, they're too handy NOT to have.
Old Jul 5, 2012 | 08:24 PM
airmark's Avatar
airmark
Ok pulled the deck.found out it had been spliced.all the wires are nutted toghether exept the drivers side? i figure match color to color but they dont match up.does anyone have a diagram of what the plug wires go to? sterio has a factery plug in it but after 4 inches of wire it turns into a rats nest.
Old Jul 5, 2012 | 08:26 PM
airmark's Avatar
airmark
i have 5 wires inside dash and five off the sterio untit plug.that are not conected but were at one point.the tape fell off.lol.......dam sunken river truck ....
Old Jul 5, 2012 | 08:41 PM
2000silverbullet
This is for a '99 with the factory cd/tape player, should be close to yours:
1999 FORD F350 4DR TRUCK
WIRE COLOR
Battery LIGHT GREEN/PINK
Accesory BLACK/VIOLET
Ground BLACK
Illumination LIGHT BLUE/RED
LF Speaker (+) LIGHT BLUE/WHITE
LF Speaker (-) ORANGE/LIGHT GREEN
RF Speaker (+) DARK GREEN
RF Speaker (-) WHITE/LIGHT GREEN
LR Speaker (+) TAN/YELLOW
LR Speaker (-) GRAY/LIGHT BLUE
RR Speaker (+) BROWN/PINK
RR Speaker (-) ORANGE/RED
Radio Security YES
Old Jul 5, 2012 | 09:21 PM
airmark's Avatar
airmark
have a pic or two i took with my phone.ill post them were my truck and bronco pics are.sorry its the only place i can put a pic from my pc.if i can figure that out agian.
Old Jul 5, 2012 | 09:27 PM
airmark's Avatar
airmark
doubt it will help but pics posted under my albums.my truck and things i like? it is there i posted new pics just now.just dont know how to put them here.this is a wire nightmare for me.
Old Jul 5, 2012 | 09:30 PM
airmark's Avatar
airmark
if i try ...tryell and eror will it burn up the radio? thinking key on and start twitsing wires untill i get sound?
Old Jul 5, 2012 | 09:37 PM
FordGuy85's Avatar
FordGuy85
Sounds like i needs to get me one!
Old Jul 5, 2012 | 10:01 PM
  #28
airmark's Avatar
airmark
i used 4 3x131 hitachi gun nails to pull my deck.insert 1 and a 1/4 inch in holes and wallaa pull nightmare out.
Old Jul 6, 2012 | 05:28 AM
  #29
2000silverbullet
I would hook them up, then turn it on to test. You don't want to short the outputs on the deck, otherwise you'll be forkin' out money for that. Also, make sure any bare wires aren't touching anything.
Maybe get some alligator clips on a 12" piece of wire to test them with? Might save you a little time. Make sure to put your fader/balance back to center.
And just so you don't feel alone in the "stereo troubleshooting" department, I'm sorting out issues with mine as well.
Old Jul 6, 2012 | 01:34 PM
  #30
airmark's Avatar
airmark
ok todays radio gig......finaly had all 4 speakers cranking away.sounded realy good two. i go to push the deck back in and as soon as it snapped inplace all sound shut off.now i gots no speakers.clock shows on sterio,stations tune in but no sound....got to looking around at the deck while i had it out.i dont think the plug or the deck were origanal.going to a junk yard to see if i can find a deck and harness. after the radio is fixed i am moveing to the cruiz controll and then to the tire rubbing issue.stay tuned.lol...with sound
