Removing Steering Column
Old May 8, 2003 | 01:57 PM
acheers's Avatar
acheers
-1975 360 auto tranny-
Hi-
While trying to replace the steering coupler disc on my ford I realized that it needed a whole new coupling. Some of the teeth or whatever on the coupling are smooth. Anyway I have the bottom part of the coupling (with disc) removed from the gearbox and I have the column loose in the truck (it moves around freely and is lying on the seat) Now how do you removed the entire column, I want to rebuild it with new bearings and coupler. The top part of the coupler is still connected, I assume I just need to beat that off with a hammer. But how do you disconnect the tranny shift lever and linkage from the column? I want to pull the entire column out. Any tips would be appreciated.
Thanks-
Alan
Old May 8, 2003 | 06:37 PM
Mil1ion's Avatar
Mil1ion
You can either disconnect the lever from the transmission or spray a little WD-40 on the end with the plastic grommet (Column end) and use a pair of water pump pliers to pry it out.
Unplug the T/S connector
The coupler takes a 11 mm 12 point socket to remove it.
4 or 5 bolts to the firewall ,2 under the dash that's it.
