Really odd problem
Old 07-05-2012, 03:38 PM
fordpride's Avatar
fordpride
fordpride is offline
Originally Posted by SamVe
Soon as I get back to the house I'll get on her.
I been thinking the samething today
  #107
Old 07-05-2012, 05:20 PM
SamVe's Avatar
SamVe
SamVe is offline
Ooo, naughty. LOL. Didn't catch what I said at the time. Not a bad idea now that you mention it. Ok. Took apart and being cleaned. How important is that heater? For some reason my wire has been cut. Anybody know what the ohm reading should be so I can check it? Pretty sure I zapped that fuel pump today. When I was reinstalling I pushed the spring all the way in and then screwed on that cap nut. Guess the tit on the nut didn't line up with the end of the spring and the spring bent over 90° and got between the nut and plunger keeping the plunger from opening. Probably put to much stress on the pump. Of course the parts store doesn't need to know all of this. I learned to let the spring stick out a little and align the tit with the end of the spring first. Learned something anyway.
  #108
Old 07-05-2012, 05:35 PM
fordpride's Avatar
fordpride
You don't need the heater
  #109
Old 07-05-2012, 06:11 PM
SamVe's Avatar
SamVe
SamVe is offline
Kinda suspected I didn't really need that heater. Just doesn't get THAT cold here. Up north maybe.
  #110
Old 07-05-2012, 06:49 PM
madpogue's Avatar
madpogue
madpogue is offline
Even up here, it's not needed. It was designed back when diesel fuel was not nearly as good, esp. in the winter, as it is today. If you run any sort of winter fuel treatment (Power Service white bottle, etc.) in the north, you're fine without that heater.
  #111
Old 07-06-2012, 05:56 AM
SamVe's Avatar
SamVe
SamVe is offline
Scratch one heater. Think it'll ever get cold enough here that I'll need the block heater?
  #112
Old 07-06-2012, 06:21 AM
fordpride's Avatar
fordpride
I'd keep the block heater
  #113
Old 07-06-2012, 06:31 AM
madpogue's Avatar
madpogue
madpogue is offline
+1; you never know where you'll have to drive it, when. And one day a northerner might want to come down and buy it (we like to do that kinda thing.....).
  #114
Old 07-06-2012, 06:47 AM
SamVe's Avatar
SamVe
SamVe is offline
I wasn't planning to get rid of it. Just wondering if I'll need it. I'm not sure at what temp you would need it. Doesn't get below the teens very often here.
  #115
Old 07-06-2012, 07:00 AM
madpogue's Avatar
madpogue
madpogue is offline
Below 0F it's important. Below 20F it's helpful but not necessary. When we go out to our cabin in the winter (rustic, no electricity), and have to start it below 20F, I used to bring out a generator. Now I just let the glow plugs run 30-40 seconds after the WTS light goes off and crank it. Cranks a little longer, some white smoke, but she always fires up. 'Course, we also run 5w30 and winter (white bottle) Power Service. For you, prob not worth the hassle of dragging out the extension cord.
  #116
Old 07-06-2012, 07:15 AM
SamVe's Avatar
SamVe
SamVe is offline
I was kind of thinking if it got below the teens or if it was going to be below freezing for a few days, which rarly happens either. We might have about 3 days in a row that stays below freezing once or twice a winter. Might be overkill to plug it up then. At least I would have a warm heater.
  #117
Old 07-06-2012, 07:27 AM
madpogue's Avatar
madpogue
madpogue is offline
^^^^ If you leave the HVAC set to windshield defrost when you part the truck, then plug it in, it clears the inside nice & quick. Oh remember, you only need it for 2-3 hours before you start it up, and it draws 1000 W (15 cents / hour, give or take), so put it on a timer if you expect to use it.
  #118
Old 07-06-2012, 07:35 AM
SamVe's Avatar
SamVe
SamVe is offline
Those are some good tips I'll take advantage of. Thanks much.
  #119
Old 07-06-2012, 10:09 AM
SamVe's Avatar
SamVe
SamVe is offline
Got the pump. Debating whether to go ahead and put it on or not. Parts store guy wants to know if it fixes pressure problem. Of course he doesn't know about the rest of the stuff.
  #120
Old 07-06-2012, 10:30 AM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
Put it on. There is nothing in the stuff you're getting from Bob that will affect the pressures. Unless you just want to wait until you have the o-rings to put it back together since you have the bowl out.
Quick Reply: Really odd problem
