1978 - 1996 Big Bronco
intermitant wipers suck
Old May 8, 2003 | 11:42 AM
house's Avatar
house
I searched and did not find anything... but my wipers on my 94 ford bronco are not working correctly, if you just turn them on they work ok, not real smooth but both high and low speed crank the wipers no problem... but the intermittant wiper feature does not work, if you turn them on you get on pass then nothing...
any suggestions? is there a relay that can be replaced? I assume the jerking motion is coming from dry linkage an a shot of wd40 will bring them back to health...
thanks in advance
nickolas
Old May 8, 2003 | 12:15 PM
greystreak92's Avatar
greystreak92
Their is a wiper control module under the dash I believe on the passenger side. There are a few people here who have replaced this module for similar reasons. Someone who has actually had to mess with this component should be along soon enough.
Old May 8, 2003 | 03:05 PM
steve83's Avatar
steve83
The Wiper Control Module (WCM) is mounted to the air duct on the R side of the glove box, and you can see it by folding the box all the way down (so it dumps on the floor). They're known to go bad, so expect to replace it.
I'd use aerosol white lithium grease instead of WD-40.
