Inside door handle, spring
Old Jun 28, 2012 | 10:32 PM
70-360fe's Avatar
70-360fe
My inside door handle is starting to work hard making the door hard to open. I have never taken the door handle apart/off just wondering what to look for if I need to take off/apart handle to fix.
Was also wondering about door spring, mine never had any. Is possible to get a new/used spring to replace the missing 2. Thanks.
Old Jun 28, 2012 | 11:23 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The spring is made as part of the door remote control, not available by itself. What year truck do you have? 1967's use one year only parts, not the same as 1968/72.
Old Jun 29, 2012 | 06:01 AM
70-360fe's Avatar
70-360fe
Sorry 1970 xlt.
Old Jun 29, 2012 | 09:02 AM
MIKES 68 F100's Avatar
MIKES 68 F100
does 70 have squeeze type ? if so problem is probably a worn arm
a new inside handle will fix it (inexpensive) , take the arm rest off and the handle (two small nuts ) look at arm that goes into door if you see a divet in end there's the problem .
my 68 had same problem .
Old Jun 29, 2012 | 01:26 PM
NumberDummy
The inside door handle itself isn't the problem as it has no moving parts. The problem lies with what's behind the inside door handle.
1968/72 F100/750: All have squeeze type inside door handles. Handle nestles to cup, behind cup is a flat reinforcement plate and the door latch remote control, has a coil spring made as part of it.
The control has two threaded studs, these pass thru the reinforcement plate, thru the cup, thru the door handle, are retained by nuts.
E9UZ-1521818-B (replaced E9UZ-1521818-A; D5TZ-9721818-A & B; C8AZ-6221818-A & B) .. Right Door Latch Remote Control / Available from Ford.
MSRP: $62.73 // FTE Ford Dealer Parts Dept sponsor tousleyfordparts.com price: $41.40.
Applications: 1968/72 F100/750 / 1968/77 Bronco / 1969/91 Econoline R/Front Door, R/Side Hinged Door & Back Door / 1986/90 Aerostar // 1968 Galaxie/LTD / 1968/69 Fairlane/Torino / 1968/70 Falcon / 1968/71 Thunderbird.
E9UZ-1521819-A (replaced D5TZ-9721819-A & B; C8AZ-6221819-A & B) .. Left Door Latch Remote Control / Available from Ford.
MSRP: $29.67 // tousleyfordparts.com price: $19.58.
Applications: 1968/72 F100/750 / 1969/91 Econoline L/Front Door / Other applications same as above.
Why is the left side much cheaper than the right side? Ask FoMoCo.
Old Jun 29, 2012 | 08:29 PM
70-360fe's Avatar
70-360fe
I picked up a nice shine handle off an econoilne a few weeks ago from the junkyard. I will see if it's in good shape. Mine were pitted snd looking bad Hopefully that fix one side. Sounds like it's not repairable? Guess I'll have to start looking at new, thanks.
Old Jun 29, 2012 | 08:56 PM
MIKES 68 F100
lmc ,npd, dennis carp all have new for cheap
Old Jun 29, 2012 | 09:09 PM
70-360fe's Avatar
70-360fe
Just checked DC is this what i need?
http://www.parts123.com/parts123/yb....Z5Z5Z50000024D
Old Jun 30, 2012 | 02:36 AM
NumberDummy
It is, if you need the left (drivers) side. Notice it's listed under the original Ford part number: C8AZ-6221819-A = replaced in 1975 with: D5TZ-9721819-B = replaced in 1989 with E9UZ-1521819-A
Carpenter: $20.00 / FTE Ford Dealer sponsor tousleyfordparts.com (Tousley: White Bear Lake MN) price: $19.58 / Since you're closer to NC than to MN, shipping will prolly be less.
Old Jun 30, 2012 | 10:27 AM
70-360fe's Avatar
70-360fe
DC has both sides that is not a problem, 20.00 bucks for either side. Guess i will have to take mine out compare then see which supplier would be cheaper with shipping. Thanks for the help!
Old Jun 30, 2012 | 01:40 PM
MIKES 68 F100
no actual chrome handle is what fixed mine
Old Jun 30, 2012 | 01:41 PM
MIKES 68 F100
finger that goes thru base gets worn.
Old Jun 30, 2012 | 02:35 PM
70-360fe's Avatar
70-360fe
I'm going to take everything out this afternoon and check it, now I know what to look for.
Old Jul 9, 2012 | 10:22 PM
70-360fe's Avatar
70-360fe
The finger on the door handle was worn so i replaced it. Fixed problem but still worked hard so I sprayed pb blaster in the the door latch, it now works smooth and easy. Just a quick update, thanks.
Old Jul 10, 2012 | 08:44 AM
MIKES 68 F100
Glad to hear , lube is always a good idea on 40 year old parts
