Power Steering Squeal
Old Jun 28, 2012 | 10:45 PM
Alcaeus's Avatar
Alcaeus
The fluid level is always ok on it though. So I dont think I'm losing fluid. At least not at a noticeable rate.
Old Jun 29, 2012 | 11:46 AM
Dave83's Avatar
Dave83
I had that exact problem 03/12! Make sure your belts are lined up. Mine was squealing so bad I didn't even want to drive it to work. I looked around a little bit and made sure my belts were tight when I noticed it. I had been driving it for a week like that. Hope this helped.
Old Jul 27, 2012 | 03:46 PM
Alcaeus's Avatar
Alcaeus
Well I gave it a thorough once over again and found a piece of junk stuck in the travel slot that the bolt goes through in the power steering bracket. It kept me from tightening it up all the way thus causing belt squeal... I also ran a file across the pulleys as they were super polished and letting it slip.
Thanks for the time and suggestions all. Mystery solved.
ON the plus side that means money can go to fun stuff now!
Kevin Bradshaw
May 23, 2019 08:11 AM
JGRNAUT_7.3L
Nov 26, 2017 04:45 PM
Uni Moe
Jan 23, 2015 11:34 AM
smalls7676
Nov 5, 2014 09:23 AM
andyman91
Apr 19, 2010 05:08 AM
