system overcharging
Old Jun 26, 2012 | 04:56 AM
alpar80's Avatar
alpar80
system overcharging
Noticed battery smelling like sulfur and no water in terminals. Replaced alt and batt. Still happening, so I replaced volt reg, still overcharging @ 16-17 volts... Any reason why this is occuring?
Old Jun 26, 2012 | 04:20 PM
The Masked Rider's Avatar
The Masked Rider
I would like to see someone answer this one also.... ?
Old Jun 26, 2012 | 09:46 PM
rusbukt's Avatar
rusbukt
I'm going with a bad ground wire.?
Old Jun 26, 2012 | 09:55 PM
Customcab's Avatar
Customcab
I was going to guess voltage reg; so I'm stumped. Have ya done a search for other post similiar?
Old Jun 26, 2012 | 09:59 PM
The Masked Rider
Is it some how bypassing the reg or maybe a bad - new reg. Anything is possible.
Old Jun 27, 2012 | 05:01 AM
alpar80's Avatar
alpar80
Is it possible one of the leeds from the alt is in the wrong spot?
Old Jun 27, 2012 | 11:42 PM
wayneo's Avatar
wayneo
When the wrong alternator has been installed in a stock vehicle or if the pulley has undersized dimensions (causing extra alternator rotation), the charging supply will be higher than the demand and cause an overcharged state. Parts house didn't sell you a higher amp alternator than you needed and tell you it will work or even possibly sell you one with internal regulator I hope. As far as the external regulator it has three electromagnetic contact switches inside its housing that open and close. A stuck contact switch that refuses to disengage will cause an overcharging problem. Keep it posted.
Old Jun 28, 2012 | 03:10 AM
63' f100's Avatar
63' f100
Is it a generator upgrade or is it the stock alternator?
fletch420man
May 1, 2013 06:44 AM
ihateminimumwage
Electrical Systems/Wiring
73
Apr 22, 2009 06:27 PM
1950ford
Nov 1, 2007 07:17 PM
markjw
Apr 12, 2006 11:46 PM
pootscratch89
Feb 23, 2006 07:37 AM
