No spark from distributor to plugs
I am back it has been so long since I last visited that I forgot my user name.
Anyway It is because I have finaly found time to work on this truck again. I am to the point where I am ready to start the engine. I had to pull the original 215 because it was junk but I was able to find a 223 from a wrecked 54 Ford Car. I have it in the truck and have all the wiring reconnected. I stayed with the original 6 volt system. Everything is wired correctly but there is something I am missing. I have power all the way through the system up to the top of the rotor button. I have power at the points. The Coil is the original to the truck. It has Bat on one side and distributor side on the other. Originally the distributor was mounted up side down.(which goes against everything I was ever taught) Anyway going through my old photos I don't have one that shows a clear veiw of the way it was wired. Am I Missing A ground Wire?? I can't remember if the thing was grounded or not. The Distributor is the one that came with the engine. I grounded the engine to frame. I am not saying the voltage is correct but I do know there is power all the way to the points with a power light. I did swap the rotor button but no luck there either.
You have 6v at the rotor button? I don't see how! You should have high-voltage spark power there when the points open/close, but I can't thnik of any way to measure it directly. Are you getting spark out of the coil, but not to the plugs? Is the little carbon plunger in place on the inside of the distributor cap?
Do you mean the coil was upside down or the distributor??
After now practicing with my old distributor I found that getting the old wire out from under the plate is not to hard but trying to get wire back under the plate from one side to another will be take lots of patience. the cloth on that wire was junk so i feel this wire is equally bad shape also. Finding those 2 small connectors will be more challenging.
https://www.ford-trucks.com/forums/6...-question.html
Here are some more numbers:
NAPA ECH LW40 - $12.99. special order http://www.napaonline.com/Catalog/Ca...W40_0366065575
(from NumberDummy) CODF12216A .. Distributor Primary Lead (Motorcraft DW10)
Thanks guys for all the suggestions and part numbers. I wasn't able to work on it today but I will hit tomorrow. I have a Napa distribution center nearby so I will be able to get it.
I couldn't figure how to get that plate out of the distributor so that is why I practiced feeding the wire under the plate.I don't have a manual yet so I am learning as I go. I am going to test the resistance on the coil look for spark at the points while it is spinning. I will still replace the wire for piece of mind no matter what else I find.
