high idle after driving
Old Jun 25, 2012 | 04:41 AM
ryito1122334455's Avatar
ryito1122334455
hi very odd thing started happening,89 f150 4 speed with the 5.0 302 ...started idiling at like 1500 the other day. itll start up and idle under 1000rpm... but once the motor gets warm it shoots up to 1500....any ideas. i got the pil leak from the oil pan, but i keep all my fluids full daily. only seems to be loosing oil and coolant
Old Jun 25, 2012 | 07:14 AM
rla2005's Avatar
rla2005
Check for codes.....Sounds more like a vacuum leak, but no sense chasing your tail until you see if the PCM thinks there is a problem.
Old Jun 25, 2012 | 09:46 AM
whiteboyslo's Avatar
whiteboyslo
Agreed on the vacuum leak, but a bad Idle Air Control Valve will also affect idle.
Mike
Old Jun 26, 2012 | 01:40 AM
TexasGuy001's Avatar
TexasGuy001
Like they've said IAC or vacuum leak.
almonyspm1
Sep 21, 2013 08:27 PM
GeorgePBurdell
1983 - 2012 Ranger & B-Series
Mar 5, 2010 11:26 AM
PauL3861
Jun 24, 2009 07:31 AM
kalawikimaui
May 29, 2008 06:02 AM
myhoneystruck
Apr 8, 2007 12:22 AM
