>>> PITMAN ARM PULLER <<<
Old Jun 24, 2012 | 09:22 AM
LongRider's Avatar
LongRider
I am looking at three pitman-arm pullers:
MATCO PA643
OTC 7311A
OTC 7310A
For use on my 1985 F-350, 1972 F-250, and 1990s Dodge 3/4- and 1-ton trucks, which of these three choices would be my better option ??
Will all three of them serve my needs, or are any of them a NO GO ??
Thanks.
Old Jun 24, 2012 | 02:23 PM
Gary Lewis's Avatar
Gary Lewis
MATCO PA643
OTC 7311A
OTC 7310A
Thanks.
If you've been looking at the on-line why not give us the links to the tools? It has been several hours since you posted and there have been no responses, so I'm guessing that others are thinking the same thing - help us help you by making it easy for us. And, by giving us the links you ensure we are all looking at the same thing.
Old Jun 24, 2012 | 08:51 PM
LongRider's Avatar
LongRider
Here are the OTC pullers :
Amazon.com: OTC 7311A Pitman Arm Puller: Automotive
Amazon.com: OTC 7310A Pitman Arm Puller: Automotive
I do not have a link to the MATCO one.
I was hoping someone that actually owned any of these pullers would respond, saying "I have such-and-such one and it works on my F-350"
Thanks.
Old Jun 24, 2012 | 09:02 PM
Gary Lewis's Avatar
Gary Lewis
I can't tell the difference between the two OTC pullers as it looks like they used the same picture, and then I can't tell which of the two is the same as the Matco puller. IOW, they all look alike but one of the OTC's is bigger than the other.
I like any of those better than my puller as mine has fixed arms and almost doesn't fit our trucks. Those pullers all have adjustable arms so should be able to be adjusted to fit whatever you are working on.
Old Jun 24, 2012 | 09:24 PM
Stangrcr1's Avatar
Stangrcr1
Looking at the specs, the 7310 is larger than the 7311.
Bigger is better, especially with trucks.
And here is bigger yet. Super Duty sized.
And here is one made for Ford F250/F350.
Old Jun 24, 2012 | 09:36 PM
Gary Lewis's Avatar
Gary Lewis
I think the last one may be the one I have. I'll try to remember to measure mine tomorrow, but that's certainly what it looks like. And it only caught one side well and the other side just barely. It worked, but I was afraid something was going to break.
Old Jun 24, 2012 | 09:41 PM
1983F1503004x4's Avatar
1983F1503004x4
I can't say it'll work on all of those trucks or not, but I just bought a non-adjustable 14$ pit man arm puller from Autozone made by OEM. It was the bigger one they had. Fit my truck perfect and worked. I didn't buy one that was adjustable because I didn't need one that was adjustable, and this inexpensive one did the job very easily. Broke my pit man arm loose without a problem. I did have to use my leg as a cheater bar though.
Old Jun 25, 2012 | 09:49 AM
Grubbworm's Avatar
Grubbworm
This is one of the ones that I used when I did mine.
Although, I broke this one and while waiting on a warranty replacement, I bought a different one from Napa and used it instead. I also had to pull my tie rod ends, so all was well and I actually did need both of them.
This is a link to one that is similar to the other one that I purchased and used. OEM/Damage free tie rod end remover for import and many front wheel drive vehicles (27175) | Tie Rod End Puller | AutoZone.com
Old Jun 25, 2012 | 10:02 AM
1983F1503004x4
That's almost identical to mine. Mine has a lot more meat on it at the jaws than yours did though, and not quite as skinny. I wish they would've made the nut on the end of the bolt a little bigger though. More meat can't hurt.
Old Jun 25, 2012 | 11:17 PM
LongRider's Avatar
LongRider
Originally Posted by Grubbworm
I broke this one
I had a brand-new one like that pictured and an ear snapped off it before I even got the slack took out of the threads.
It didn't even put on a good show before it give up.
Hence, my quest for something a bit more dependable before I undertake the task again.
I have a shiny new REDHEAD and would like to get it installed so I can enjoy the wonderful driving experience they are so highly acclaimed for.
Thanks and keep the information coming.
Old Jun 26, 2012 | 09:46 AM
Grubbworm's Avatar
Grubbworm
The opening in the jaws was actually slightly larger than I needed it to be. I ended up purchasing a different type of one, and warrantied that one. Now, I have two different ones. I need to get a picture of them together.
Old Jun 26, 2012 | 09:49 AM
Gary Lewis's Avatar
Gary Lewis
That's exactly the problem I had - slightly too big. It would catch well on one side but only on the tip on the other. That's why I like the idea of an adjustable puller.
Old Jun 26, 2012 | 10:29 AM
Anafiel's Avatar
Anafiel
I like the looks of that Super Duty OTC puller.
I think I'll get one of those when I get mine. I REALLY need a new Redhead for my truck...soon!
(Steering, guys...the redhead in the house is just fine)
Old Jun 26, 2012 | 10:46 AM
Gary Lewis's Avatar
Gary Lewis
I'm very, VERY happy with the brunette I have.
Old Jun 26, 2012 | 11:53 AM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
I have a Snap-on one that looks like an open sided cup and one of the light duty ones. I also have one you drive between the box an the arm.
