Coil wiring
Old Jun 22, 2012 | 07:33 PM
mlis's Avatar
mlis
Coil wiring
Hello
I bought a new coil and forgot to look at how the old one was wired. I have 6 volt positive ground V8 Flathead. Does the wire coming from the ignition switch go to the positive or negative terminal on the coil? The Ford shop manual does not show this. Thanks
Old Jun 22, 2012 | 07:38 PM
f5fordgirl's Avatar
f5fordgirl
On a 6 volt setup with pos ground, the switch wire goes to the negitave coil post.
Old Jun 22, 2012 | 07:52 PM
mlis's Avatar
mlis
Thanks
I have one other question. I tried to set the timing but my timing light does not work with a 6 volt system. Do you know how to use a timing light with a 6 volt system?
Old Jun 22, 2012 | 08:05 PM
f5fordgirl's Avatar
f5fordgirl
Hook your timing light to a 12 volt battery.
Old Jun 22, 2012 | 08:20 PM
mlis's Avatar
mlis
It sounds so simple. I will time it tomorrow.
wmkmun
Aug 17, 2016 08:39 AM
loudfords
20
Oct 25, 2014 07:31 PM
1979 F-150 4x4
Nov 16, 2011 07:12 PM
TFagerholm
17
Jun 8, 2009 05:26 PM
58ford
Jan 13, 2002 08:01 AM
