need help with trans id
Old Jun 22, 2012 | 01:03 AM
iontkendall's Avatar
iontkendall
I am currently looking at purchasing a borg warner trans. The #'s on the case are 13-09-066a and 13-09-097-093. I am told this is a 5 speed manual trans from a 1996? f ??? series with a 7.3 diesel. I can post more #'s found on the case if needed. I would like to know what the ratios are for each gear. Hope someone can help
Old Jun 22, 2012 | 12:01 PM
85e150's Avatar
85e150
That is most likely a T19, a FOUR speed trans. Pics here, note comments on casting numbers on case:
Domestic Truck Tranny Guide
Ford used ZF for the 5 speeds, not BW. (Note there are no BW 5ers listed in that link...)
More info including ratios, note the 4.02 first gear is most common:
The Borg-Warner T18 & T19 Transmissions - Novak Conversions
Depending on your other drivetrain items and intended use, it might be a good trans for you.
Old Jun 22, 2012 | 10:13 PM
iontkendall
is there any chance that this is a 5 speed from another truck. This is most definitley a 5 speed trans as it has 5 forward gears and 1 reverse. Could eaton be a possibility? I am confused. The rest of the trans #'s are E6T3-LA
13-09-066A
C247
47120
C10-07
13-09-097-093
13-09-065-0911
Q1
E6T0-LA
Old Jun 22, 2012 | 10:20 PM
85e150's Avatar
85e150
Are you looking at the trans? How does it compare to the pics in the top link above? How do you know it has 5 gears, did you drive it? If it's a T19, it's a 4 speed.
Search "Borg Warner 5 speed" and all you will find is the T5, maybe the T50. Keeping in mind this is wiki, no 5er listed here--not proof of course:
BorgWarner - Wikipedia, the free encyclopedia
way2fast1
Apr 26, 2011 10:23 PM
cfd2410
Oct 14, 2009 12:12 AM
Bill_Beyer
Sep 21, 2001 05:35 PM
