quick question on GPs
Old 06-19-2012, 06:35 PM
jle70's Avatar
jle70
jle70 is offline
What wire actually activates the solenoid? From PCM or the other one?
Old 06-19-2012, 07:45 PM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
The PCM sends ground to the solenoid to activate it.
Old 06-19-2012, 08:06 PM
mjonesjr's Avatar
mjonesjr
mjonesjr is offline
The PCM uses the Brown w/ Red Stripe to activate the glow plug relay. The PCM grounds that wire out thus causing the glow plug relay to activate.
Old 06-19-2012, 10:23 PM
jle70's Avatar
jle70
jle70 is offline
So why do I get 12v with key on? It should be 0 if it is a ground, right? And this is with it off the solenoid.
Old 06-19-2012, 11:04 PM
madpogue's Avatar
madpogue
madpogue is offline
On the brown/red wire or the red/green?
Old 06-20-2012, 06:12 AM
jle70's Avatar
jle70
jle70 is offline
I tested red/green. I assumed that is what activates it,
Old 06-20-2012, 07:05 AM
mjonesjr's Avatar
mjonesjr
mjonesjr is offline
You assumed wrong. I guess you completely forgot to look at the post above where I said it was the Brown w/ Red Stripe wire that activates the glow plug relay
The Brown w/ Red Stripe will have 12v on it until the PCM grounds it out, then it will have 0v and it will ohm to ground.
Old 06-24-2012, 12:14 PM
jle70's Avatar
jle70
jle70 is offline
I did read what you wrote, and my reply was if PCM wire goes to ground, then why would I read 12v from it when disconnected. If it goes to ground then it should be 0v.
Old 06-24-2012, 12:27 PM
mjonesjr's Avatar
mjonesjr
mjonesjr is offline
You will read 12v on the Brown w/ Red stripe wire when the PCM isn't grounding the wire.
Carl Brown
25
02-21-2013 06:51 PM
Pro DIY
10-10-2012 02:14 PM
Joshglov
02-14-2010 05:46 PM
woodsy188
07-01-2008 09:38 AM
gtlegacy
12-24-2007 05:51 AM
Quick Reply: quick question on GPs
