Sponsored by: Real Truck
Wandering
Old Jun 18, 2012 | 06:55 PM
mark318's Avatar
mark318
Wandering
Hello All Newby here
Just bought a 2008 F350 to haul a 5th wheel camper with. The dealer had just installed new Procomp Extreme tires. Size 35-12.5-20. I dont know if it is the tires but I find I am constantly having to correct the steering as I drive, it seems like it tends to wander all over the road and I have to pay constant attention to it. It has just 100k miles. I am wondering if the steering stabilizer has reached end of life. If anyone has any suggestions I would love to hear them. It is going in for an inspection tomorrow and they will give it a thourogh once over.
Mark
Old Jun 18, 2012 | 07:15 PM
sand_fiend's Avatar
sand_fiend
They need to check the ball joints, drag link and tie-rod ends. Is there play in the steering wheel ?. have someone rock the wheel left to right and see how far it will turn before the wheels start to move. look under the truck at the tie-rod ends is there movement slightly after the steering wheel is turned ?. look at the pitman arm off the steering box. how far will the steering wheel move before the arm moves ?. Is the truck geared to pull 35's ? It will kill you mileage if its not !.
Some over size tires will make your truck drift.
Old Jun 18, 2012 | 07:24 PM
mark318's Avatar
mark318
On that topic the computer says I am getting about 12.4 mpg. The tires are way more than what I will ever need and was thinking of trying to sell them. They go for $460.00 each. A BF Goodrich standard OEM size 275-65-20 is 34.1 inches in diameter. Will that .9 inches make that much of a difference? What can I expect for mileage. 12.4 does seem low. It is the 6.4 diesel.
Old Jun 18, 2012 | 07:37 PM
redford's Avatar
redford
FTE Leadership Emeritus
Yes, the .9 inches does make a difference. I went from the stock 265 BFGs to a 285 (about 1 inch taller) and noticed a sizable decrease in torque when towing, not to mention the wider tire has a lot more drag.
Old Jun 18, 2012 | 07:40 PM
sand_fiend's Avatar
sand_fiend
If you click on the form bar on the top left. then click list. you can scroll down to the 6.4 diesel form. these guys are great on this site on all the forms. you will be learning a lot about your truck and how to fix things your self. there are lots of mods to get more power and mileage from your truck.
link to 6.4 form.
6.4L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Bird-Dog 250
Dec 2, 2015 05:50 AM
Dan Taylor
Dec 2, 2013 07:48 AM
Alcoa
Feb 13, 2013 08:27 AM
abriel68
Mar 29, 2010 03:32 PM
tonyevans69
1983 - 2012 Ranger & B-Series
Aug 27, 2002 09:40 PM
