single shot vs. split shot?
Old Jun 17, 2012 | 12:53 PM
fordman67's Avatar
fordman67
Ok.for my 96 truck cc....i have an extra set of ad injectors....
should i plan on having them done for my truck someday if i need them for this engine or more importantly i hope to build the 2k truck engine and swap it in in place of my 320000 mi engine....or just sell them and put the money into my single shots? I have something else to drive so when the time comes down time is not a big deal....just thinking ahead and not sure how wich way is better...
Old Jun 17, 2012 | 01:06 PM
glovemeister's Avatar
glovemeister
Single shots are supposedly better for power and mpg.
Splits are good for noise and emissions I believe.
Old Jun 17, 2012 | 03:18 PM
fordman67's Avatar
fordman67
I was just curious that since the AD's are worth 140ccit and my stockers only 90cc if i just had the ads reworked if it would be better than stock enough or stage 1 single shots would be better.i suppose i should call jim?
Old Jun 17, 2012 | 03:51 PM
DIYMechanic's Avatar
DIYMechanic
The single shots will use less HP Oil than the Splits will. You will need a 17* HPOP at least to run the splits. That and tunes that are designed for the splits hots sticks. Of course you're going to need to have tunes to take advantage of the Stage 1's as well, but those would probably run on stock HPO as long as your HPOP is healthy (but if it has 320k on it.....).
It's really just a matter of what you're after. The split shots run a little quieter (sounds like a SD 7.3) than the singles, but for all out power and performance, the Singles are king.
Old Jun 17, 2012 | 04:33 PM
fordman67's Avatar
fordman67
Ok,sounds like im keeping the singles....one more question.when i do the 2000whole motor that has a hpop on it in my truck....can i run the 17 degree pump on my singles...im thinking it may be better but i am formulating my plan if you know what i mean....thanks for the help!
Old Jun 17, 2012 | 05:37 PM
tshrager's Avatar
tshrager
Yes sir. I'm running the SD 17 on stock sticks, lots of guys do it.
Old Jun 17, 2012 | 08:16 PM
fordpride's Avatar
fordpride
If your trying to keep a budget and the AD's are in good shape and don't need a rebuild then get a chip burned for splits and run em. If they need to be rebuilt then sell em and have your AA's built as it cost more to turn splits into stageI single shots
Old Jun 17, 2012 | 08:23 PM
fordman67's Avatar
fordman67
The ads were in a core engine i have.i know nothing about them.the engine appears to have been dusted from the build up in one cyl. I will prob sell the splits for what ever i can get and put the money into something for the truck.maybe a chip
Old Jun 17, 2012 | 08:30 PM
fordpride's Avatar
fordpride
There is a guy in the classifieds that will give you atleast 350 for them as cores.
Old Jun 17, 2012 | 08:33 PM
fordpride's Avatar
fordpride
The first guys are buying cores
Ford Truck Enthusiasts Forums - Search Results
fordman67's Avatar
fordman67
Hmmm.i like the sound of that..thank you very much!
Old Jun 17, 2012 | 08:35 PM
fordpride's Avatar
fordpride
Look at my last post. Not sure if you seen it. Jocaren bought mine very good guy to deal with
Old Jun 17, 2012 | 08:45 PM
fordman67's Avatar
fordman67
I did,i posted.then saw the last page.he buying no 7.3 now.but it was a month ago....maybe he is again.thanks for the lead though!
Old Jun 17, 2012 | 08:48 PM
fordpride's Avatar
fordpride
Yea he's always changing what he is buying. He is alway looking for 7.3, 6.0, Xmas and cummins injectors
JOHN2001
Apr 24, 2012 11:04 PM
JonathanN
77
Mar 28, 2010 07:29 PM
cjfarm11
24
Jul 15, 2009 08:17 PM
Tim Shultz
Mar 25, 2008 08:21 PM
Mr. Bob
40
Oct 2, 2007 10:08 PM
