1978 - 1996 Big Bronco
Help please?
Old May 7, 2003 | 08:55 AM
BoySetsFire's Avatar
BoySetsFire
Help please?
I have an 86 Bronco with a 302 V8.
The bronco will not start up unless I hold down the gas peddle, when I take my foot off the peddle it instantly dies. Have I broken the throttle linkage or something more servere?
Thanks
Old May 7, 2003 | 10:01 AM
Kemicalburns's Avatar
Kemicalburns
Help please?
do you hear the fuel pump come on when you turn the key on. also might check to see if you have plenty of fuel pressure. You might also check your battery cables, make sure they are clean and on tight. when was the last time you gave her a tune up. you might need to replace a few plugs, wires, cap and rotor. was it running fine earlier or has this been a problem for awhile?? need more info
later
Old May 7, 2003 | 10:17 PM
steve83's Avatar
steve83
Help please?
Is it EFI or carbed?
