6 inch Skyjacker Lift Questions
#31
Those heavy flaps might leave a mark
Yea, i figured if you're moving away from the 4.10's you want a noticable difference but you still want it to be streetable.
4.56's aren't too much of a jump over 4.10's, so 4.88's or 5.13's would be my options, with more of a leaning towards the 4.88's
#32
#33
#35
#36
The block is from Jeffs Bronco Graveyard, part # 22986, cost $70. Also look at Adj Drag Link part # 22980. I used the pitman arm, drag link and block, Together It all works perfect.
#37
Thanks! I've got an adjustable drag link from Skyjacker and when you combine it with the drop pitman arm I have is supposed to be good for 5-7 inches. I found this out after reading the instructions that came with the pitman arm!. I'm gonna install them and see what kinda angle the drag link is at. If it looks like it's too much for my liking I'll order the steering block. Which kinda sucks cause I already put in an order at JBG.
#38
#39
F150offroader
07-25-2008 08:37 PM
