Transmission identification info
Old Jun 13, 2012 | 11:29 AM
craigibc's Avatar
craigibc
I was told this came out of a 80's truck. Here is the numbers on the tag on the side of the transmission:
RAT ET JA8
FI TRFA 2126
I am trying to find more info about the transmission gear ratio, shift pattern and more details about this transmission and my google search and posting on other forums and yielded little results. Hope you guys might have some answers for me.
Thanks,
Craig
Old Jun 13, 2012 | 12:02 PM
85e150's Avatar
85e150
Does this have two shift arms on the driver side?
Top loaded, iron case, tin cover on top?
Info here, with pics in links.
https://www.ford-trucks.com/forums/1...ero-trans.html
Short version, it is Ford "303" all synchro 3 speed. Shift pattern is an H, with R in the upper left, 1st the lower left, 2nd the upper right and 3rd the lower right. The pattern is the same for column shift or floor shift as found in Mustangs and Cougars with that trans. (looking at the column while leaning forward and looking left from the passenger seat you will see the "H" of a column shifter)
Ratios varied, this stolen from another site and it does not show RAT ET, but you can determine the ratio pretty easy since the 1st ratio different enough to eyeball it:
<TABLE style="BORDER-COLLAPSE: collapse" border=1 cellSpacing=0 borderColor=#111111 cellPadding=2 width="98%"><TBODY><TR><TD bgColor=#e1eaf0 width=80>RAN-E1</TD><TD width=70>240-1V</TD><TD width=286>F100 114” WB (Slip Yoke)</TD><TD rowSpan=4 width=52 align=center>2.99</TD><TD rowSpan=4 width=52 align=center>1.75</TD><TD rowSpan=4 width=52 align=center>1.00</TD><TD rowSpan=4 width=53 align=center>3.17</TD></TR><TR><TD bgColor=#e1eaf0 width=80>RAN-G1</TD><TD width=70>240-1V</TD><TD width=286>F100/250 131” WB (Fixed Yoke)</TD></TR><TR><TD bgColor=#e1eaf0 width=80>RAT-G</TD><TD width=70>300-1V
360 2V
</TD><TD width=286>F100 114” WB (Slip Yoke)</TD></TR><TR><TD bgColor=#e1eaf0 width=80>RAT-H</TD><TD width=70>300-1V
360-2V
</TD><TD width=286>F100/250 131” WB (Fixed Yoke)</TD></TR><TR><TD bgColor=#e1eaf0 width=80>RAT-V</TD><TD width=70>390-2V</TD><TD width=286>F100 114” WB (Slip Yoke)</TD><TD rowSpan=3 width=52 align=center>2.42</TD><TD rowSpan=3 width=52 align=center>1.61</TD><TD rowSpan=3 width=52 align=center>1.00</TD><TD rowSpan=3 width=53 align=center>2.33</TD></TR><TR><TD bgColor=#e1eaf0 width=80>RAT-W</TD><TD width=70>390-2V</TD><TD width=286>F100 131” WB (Fixed Yoke)</TD></TR><TR><TD bgColor=#e1eaf0 width=80>RAT-AF</TD><TD width=70>390-2V</TD><TD width=286>F250 131” WB (Fixed Yoke</TD></TR></TBODY></TABLE>
Old Jun 13, 2012 | 12:18 PM
craigibc's Avatar
craigibc
questions
to answer your questions.
yes
yes
yes
I saw that form that you listed on another site but was not sure if that was going to be the same for me.
Thanks for the great info!
Craig
Old Jun 13, 2012 | 12:20 PM
85e150's Avatar
85e150
Glad to help. I had many miles of happy motoring (and some unhappy) with a "303" in my '65 Mustang.
Old Jun 13, 2012 | 12:29 PM
craigibc's Avatar
craigibc
Does this have two shift arms on the driver side? yes
Top loaded, iron case, tin cover on top? yes
Thanks for the info!
Craig
goofy69
38
Sep 1, 2006 06:17 PM
shack girl
1997 - 2003 F150
Aug 10, 2006 08:55 PM
AzBaddBoy
Computer Chips & Tuners
Jun 9, 2006 01:23 PM
