1978 - 1996 Big Bronco
Removable winch
Old Jun 13, 2012 | 12:14 AM
henritrinelli's Avatar
henritrinelli
Removable winch
Today I started working on this.....You will ask why I didn´t use tubes.....cos the places where you can find the kind of tubes I need sells minimun 9 feet (of each kind) and cost about $270.- ...so I had to find other way to fabricate it....
Started cutting the holes in the frame....
Uploaded with ImageShack.us
This "crossmember " comes thru the holes about 2 or 3 inch on each side.....with the idea (in the future) of connect it to each end of the bumper to reinforce it....
At last it will be with 2 receivers....both behind the licence plate
henritrinelli
This is the upper U with the receivers....
Trying to put all together......
Welding the tubes
The upper U mounted....still have to weld the lower U
I think the winch will a little closer to the bumper, but I still have to make the holes on it to see how much closer I can go....
Old Jun 13, 2012 | 12:15 AM
henritrinelli
Holes in the bumper
straightening the bumper
Welding the crossmember
The bumper....much better now.....
With the minch mount in place
I cutted about 2 1/2 inches from each side of the winch mount...
Old Jun 13, 2012 | 10:53 AM
Kemicalburns's Avatar
Kemicalburns
nice work, gonna be a heavy mother to remove and such but i like it.
Old Jun 13, 2012 | 08:47 PM
roosplash's Avatar
roosplash
I for one, being a Welder / Fabricator myself, appreciate your idea on this. However Im not sure the channel will hole up to any significant load. Channel is softer than standard tube material in my experience. Im not sayin it wont work, and will be the first to say Im wrong if it does. Just not a choice of material I would choose for that application, but then again, Im not you
Old Jun 13, 2012 | 09:02 PM
bigzirb's Avatar
bigzirb
Kudos on building a removable mount for an old school Warn 8274. Having one of them myself I must recommend a back brace or good friend to help if you are going to be lifting it a lot. Nice to see all the work and I like that you are using 2 tubes to spread the load for the winch mount.
I would suggest adding some smooth handles on each side of the plate to grab it and hold on as it is hard to get a good grip on the winch. Nice work and keep the updates coming please.
Old Jun 13, 2012 | 10:02 PM
henritrinelli
Thanks, ....today we puted on the winch.....yes it´s heavy...haha....but it fits perfect so is not that hard...
Old Jun 13, 2012 | 10:10 PM
henritrinelli
Thanks man, I appreciate your opinion on that....I think this will work fine....but I´m sure that using the tubes I could have used less material to get the same strenght.....I´ll test it as soon as I finish it....
Old Jun 13, 2012 | 10:15 PM
henritrinelli
Thanks man....with the right handles , as you said is easy to put it on....but is heavy haha....But is the only way to be street legal ....laws sucks here....
Wheeling places are very far from where I live.....Dunes 300 miles....rocks 500 miles....snow 1000 miles....So my truck sees a lot of highway too....
Old Jun 13, 2012 | 10:19 PM
henritrinelli
From today.....
Old Jun 14, 2012 | 10:05 AM
Kemicalburns
If you can i would also recommend you weld in some recovery/tow point up front. this will also give you a place to have the hook when not in use.
Old Jun 14, 2012 | 11:21 PM
henritrinelli
I have 2 hooks , one on each frame rail but I´ll make something to use with the receivers
Old Jun 14, 2012 | 11:26 PM
henritrinelli
First test ......there is nothing bent......is a little tilted back cos we still didn´t weld the receiver to the frame....
Old Jun 14, 2012 | 11:31 PM
henritrinelli
The wiring....
I used an existing hole and I made it larger to fit both wires....
Old Jun 16, 2012 | 05:10 PM
henritrinelli
Today I added a couble of reinforcements from the center of tho winch mount to the engine crossmember....
Also made 2 "brackets " to mount the bumper....It was impossible to put the nuts in the upper bolts , so I used 2 strips of 1/4 metal , threaded and used them in place of that nuts.....They fit very tight and then I put the lower bolts....
