6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Navistar made our 6.4's and now lost a law suit
Old 06-13-2012, 07:25 AM
Gearitis's Avatar
Gearitis
Gearitis is offline
It looks like Navistar has lost all the way around, but thanks to the EPA it seems that there is no wiggle room for new technology, its their way (EPA) or the "hiway" no pun intended....Ya think this might have some bearing on why Ford dropped Navistar?
Heres the link folks:
http://www.chicagobusiness.com/artic...ses-epa-ruling
Old 06-13-2012, 02:55 PM
senix's Avatar
senix
senix is online now
Received 1,442 Likes on 1,031 Posts
I think this possibly had some bearing in the end. Ford knew this type of technology would not go past 2009. It is deadended.
Old 06-13-2012, 07:10 PM
Gearitis's Avatar
Gearitis
Gearitis is offline
I think the same. I do believe there may have been other avenues to pursue to satisfy the EPA. It just seems odd that Navistar had made diesel engines for years and they were trying to find a solution out of the mainstream. You wonder if Ford, their largest buyer of motors, had an influence in the decision to move in that "other' direction and then dropped them when the heat started. Oh well....
Old 06-13-2012, 07:19 PM
hytcrdnk's Avatar
hytcrdnk
hytcrdnk is offline
It's either DEF or exhaust regen systems to meet the CARB standards set by the EPA; both of which make it cost prohibitive to the average consumer.
Old 06-13-2012, 07:26 PM
mhatlen's Avatar
mhatlen
mhatlen is offline
2006 Bullet-Riddled 6.0
Whats with the urea buisness for the exhaust on the new diesels???
Old 06-13-2012, 08:00 PM
senix's Avatar
senix
senix is online now
Urea takes care of the NOx
Old 06-13-2012, 09:05 PM
ljutic ss's Avatar
ljutic ss
ljutic ss is offline
Navistar wasn't alone in paying penalties, Cummins was in the same boat.
Old 06-13-2012, 09:45 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
Thanks to the EPA?
The EPA does not care how you meet emissions standards - only that you do. You don't have to use SCR/Urea, but its currently the method that works the best.
These emissions standards were laid down in 2001 and have been in effect since 2010. 11 Years later and Navistar still hasn't gotten their act together. The only one at fault here is Navistar. The 6.0 disaster, 6.4 teething issues and their Medium/Heavy-Duty engine troubles all indicate incompetent management as well as poor engineering and testing practices.
Ford knew this and broke things off with Navistar.
Old 06-14-2012, 12:08 AM
aquaman's Avatar
aquaman
aquaman is offline
If I'm not mistaken, I seem to recollect Caterpillar withdrew from the on-road engine market as soon as the new emission standards took effect.
Old 06-14-2012, 06:44 AM
Gearitis's Avatar
Gearitis
Gearitis is offline
You know I believe you are right. CAT did pull out of that market. Now with the current push to make EPA standards for heavier vehicles conclusive by 2014, I wonder how that will play into all of the manufacturers hands?
Old 06-14-2012, 10:22 AM
parkland's Avatar
parkland
parkland is offline
Isn't cummins still using huge EGR instead of urea?
Old 06-14-2012, 10:29 AM
parkland's Avatar
parkland
parkland is offline
From what I've been told, the 6.0 and 6.4 did much better for international than ford.
Internationals 6.4 now is a CGI block, 1 massive EGR cooler, and went to dual sequential turbochargers.
Old 06-14-2012, 11:07 AM
Lead Head's Avatar
Lead Head
Talk to school bus or large truck fleet operators. Even when detuned to ~240HP in heavy-truck tunes, the 6.0 still had tons of issues.
Old 06-14-2012, 12:12 PM
parkland's Avatar
parkland
parkland is offline
I hear a few complaints, but nothing serious..
240 HP is less than the ford version, but ford tuning also uses higher RPM's, so I suspect the combustion pressures would be similar.
Old 06-14-2012, 12:40 PM
Lead Head's Avatar
Lead Head
Not just headgasket failures from combustion pressure, but injector failures, oil cooler failures, EGR cooler failures and much more.
Just search "VT365 Problems" on Google.
Quick Reply: Navistar made our 6.4's and now lost a law suit
