Navistar made our 6.4's and now lost a law suit
It looks like Navistar has lost all the way around, but thanks to the EPA it seems that there is no wiggle room for new technology, its their way (EPA) or the "hiway" no pun intended....Ya think this might have some bearing on why Ford dropped Navistar?
Heres the link folks:
http://www.chicagobusiness.com/artic...ses-epa-ruling
I think the same. I do believe there may have been other avenues to pursue to satisfy the EPA. It just seems odd that Navistar had made diesel engines for years and they were trying to find a solution out of the mainstream. You wonder if Ford, their largest buyer of motors, had an influence in the decision to move in that "other' direction and then dropped them when the heat started. Oh well....
The EPA does not care how you meet emissions standards - only that you do. You don't have to use SCR/Urea, but its currently the method that works the best.
These emissions standards were laid down in 2001 and have been in effect since 2010. 11 Years later and Navistar still hasn't gotten their act together. The only one at fault here is Navistar. The 6.0 disaster, 6.4 teething issues and their Medium/Heavy-Duty engine troubles all indicate incompetent management as well as poor engineering and testing practices.
Ford knew this and broke things off with Navistar.
You know I believe you are right. CAT did pull out of that market. Now with the current push to make EPA standards for heavier vehicles conclusive by 2014, I wonder how that will play into all of the manufacturers hands?
Internationals 6.4 now is a CGI block, 1 massive EGR cooler, and went to dual sequential turbochargers.
240 HP is less than the ford version, but ford tuning also uses higher RPM's, so I suspect the combustion pressures would be similar.
