Ford Truck Parts for Sale Ford Truck related Parts and Accessories for sale
Parts Search
Keyword:
Category:
Price:
Private or Vendor Listing:
Location (State/Prov):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Color:
Private or Dealer Listing:
Location (State):
(Sold) Four Tubeless 19.5" Wheels, Budd R89340, 5 lug x 8" Pattern
Old 06-10-2012, 05:40 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
Marmon-Herrington Man
Category: Wheels & Tires
Price: $85
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Accord, CRX & pre '92 Civic, '92+ Civic/EL & Del Sol, '06+ Civic/CSX
Item Condition: OR
Shipping Information: Item can be shipped
Engine: Part suitable for gas truck
My son has available a set of four Budd R89340s, 19.5" x 6", having the 5 lug x 8" bolt pattern. These wheels are in good shape having no bends, rust, or other road hazard damage. They are $85 each, and he will also ask that the buyer cover the $8.00 each cost of tire removal and disposal.
The wheels are in Oregon (zip code 97217) and can either be picked up or shipped at the buyer's expense. My son will deliver them to the shipper. We've had good success in the past using the local R&L Carriers depot. They put the wheels on a pallett and shrink wrap them securely. The wheels weigh 45 lbs each, and with the pallett will be approximately 200 lbs.
Stu
Old 06-20-2012, 06:43 PM
gmcolorcat's Avatar
gmcolorcat
gmcolorcat is offline
Are these still available
Are these 5 lug 19.5 wheel still available,. thanks Newbie Gary in Southern Oregon..also how is the 8" pattern measured to see if it matches my need..
Old 06-20-2012, 07:19 PM
truckdog62563
Yes, these are still available. I talked to my son this morning and he mentioned that the guy hasn't gotten back to him. The 5 lug x 8" pattern was the standard on all the older 1.5 ton Fords. These will not fit the 38-47 tonners. To find the 8" measurement you put your tape on the outer edge of one stud then measure to the middle of the third stud in the circle. In essence you jump one stud and go across to the next one. Stu
Old 06-20-2012, 08:16 PM
gmcolorcat's Avatar
gmcolorcat
My wheel has BUDD and 65 stamped on it. This is on a 1968 motorhome that was built on a ford chassis. The measurement I took was 7 and 3/4 inches doe that sound right thanks gary
Old 06-20-2012, 08:54 PM
truckdog62563
Are you measuring just between the studs, or including the nuts? It should be exactly 8" if you measure outside of stud to middle of stud. All that said, the only other possible bolt pattern would be 6 x 7.25", and you don't have six studs. What really has me scratching my head is your 14 x 17.5" statement. Some old motor homes had 17" tube type Budd wheels. But the tires would be 7.50 x 17". Any 17.5" wheel tire combo will be tubeless. Your "65" find is the year of manufacture. Is your motor home dual rear wheel or single rear? Stu
Old 06-20-2012, 10:24 PM
gmcolorcat's Avatar
gmcolorcat
single 14x17.5 .... 5 studs on the rear and 6 studs on the front wheels. I plan on using your wheels as a dual set up on the rear with 245 17 19.5 tires. I was measuring outside to outside of the bolts. I probably lost 1/4 of an inch in accuracy. I can send pictures of the wheels if that would make a difference..Thank You Gary
Old 06-21-2012, 02:34 AM
truckdog62563
Please text me pictures at (217) 741-0540. Stu
Old 06-21-2012, 07:48 AM
truckdog62563
I got a text, but no pictures. And the sending phone number looks bogus. What kind of phone number is 1 (410) 000-001? A lot doesn't add up here. Stu
Old 06-21-2012, 08:02 AM
truckdog62563
The second text has your msn email address, so I replied to it with my email address. Try that. Stu
Old 02-24-2013, 05:14 PM
Dkavfamily's Avatar
Dkavfamily
Dkavfamily is offline
Stu,
Do you know of a set of Budd R89340 rims to fit a 1948 Ford f-5? Really any rim that will fit this truck is fine! Just need to replace the widowmakers! I'm in PDX, Oregon. 971 563-6183. Dan
Old 07-09-2013, 08:50 PM
Boon's Avatar
Boon
Boon is offline
Wheels
Stu my lug distance seems to be 7 3/8 or 7 1/2. Eight inch would definately be to far. What's your thoughts on my lug distance? My wheels are 5 lug. 1951 f6
Old 07-09-2013, 09:44 PM
truckdog62563
Yours are 8". To measure a five lug wheel pattern you put your tape on the outer (furthest) edge of one stud, skip the next stud in the circle, and measure to the middle of the third stud. That will be 8". It was a standard pattern used by many of the vehicle manufacturers. Stu
Old 07-09-2013, 10:04 PM
Boon's Avatar
Boon
Boon is offline
Wheels
I see. I measured from center of lugs. Eight makes sense. I'll be needing six wheels. Do have any?
Old 07-09-2013, 10:13 PM
truckdog62563
Yeah, just got home today from Oregon with several sets. Do I recall right that you are in Missouri? I'll be leaving again tomorrow morning going to the Iola, Wisconsin, swap meet but will be back next week if you are close and want to come get a set. Stu
Old 07-09-2013, 11:19 PM
Boon's Avatar
Boon
Boon is offline
Wheels
Any way I could get them shipped?
Quick Reply: (Sold) Four Tubeless 19.5" Wheels, Budd R89340, 5 lug x 8" Pattern
