Kick down linkage.
Old Jun 12, 2012 | 07:44 PM
PRIMERED79 SHORT BED's Avatar
OK picture time.
Here is how my linkage's look closed.
[IMG][/IMG]
[IMG][/IMG]
This is with throttle all the way open, and the trans lever all the way down.
[IMG][/IMG]
[IMG][/IMG]
This is open throttle, with the trans lever spring adding up pressure.
[IMG][/IMG]
So how does it look?
Anything look out place on this setup?
I just got done screwing in the screw all the way when i took these pics.
Before there was at least a 1/4" gap between the lever and head of the screw.
Before that it was screwed in all the way, so either way, it wont help make it shift at 60mph.
Old Jun 20, 2012 | 09:41 PM
Anybody have any ideas?
Old Jun 21, 2012 | 05:27 AM
OldStyle's Avatar
OldStyle
Rusty Roller
Yes; You need to extend the kickdown linkage about 1 inch. Then adjust accordingly....
Old Jun 21, 2012 | 07:40 AM
Who makes a extension for the kickdown rod?
Old Jun 21, 2012 | 08:22 AM
OldStyle's Avatar
OldStyle
Rusty Roller
Here you go....
https://www.google.com/search?q=ford...w=1280&bih=668
Old Jun 21, 2012 | 09:01 AM
460me's Avatar
460me
Didn't know about them little guys,I went with a Lokar cable set up.
Old Jun 21, 2012 | 11:33 AM
How do you set the Cable style up?
Is better than the factory rod?
Old Jun 21, 2012 | 07:52 PM
OK ordered the extension on eBay, I'll report back when i have it hooked up.
Old Jun 21, 2012 | 09:31 PM
tbear853's Avatar
tbear853
My '77 w/351M & C-6 has always kicked down from 3 to 2 at 55-60 if I punch it. On these transmissions, you want full throttle at about same time as kick down rod linkage stops. When I went from factory 2bbl / intake to Edelbrock Performer and Holley 650 in 1987 I had to make an extension for the linkage. I used a piece of steel with two holes, near an inch apart , each hole is 5/16" diameter and one deburred. I used other hole to fasten extension to KD rod with a 5/16" bolt and nut.
It alowed me to adjust and it worked with my newer Edelbrock 1405 600 carb too. It was meant for a 2bbl carb, the 4bbl intake moved the primaries forward as now there were secondaries .... so stock link is short.
Old Jun 21, 2012 | 10:17 PM
I have the stock 2v carb tho, that's why i don't understand why my rod is to short ( easy fellas ).
Hopefully here shortly, I'll be switching over to a 4v manifold and carb, so I'll need the extension anyways.
I just want the dang thing to work like it should, anything under 60 and she'll kick down, but if I'm over 60 she wont.
Old Sep 22, 2012 | 10:23 PM
77 2wd's Avatar
77 2wd
Originally Posted by OldStyle
Might be true for a 351/400....
For my 429 (just for reference I check today) I'm turning 2700 @ 60mpg and when I put it to the floor she jumps to 4200rpm and kicks out into third @ 75mpg. C-6 4.10 & 33's
Here's the adj procedure...
what does it mean, by insert a .60 spacer? not sure what it means by inserting the spacerr
672wd72highboy
27
Jun 14, 2014 12:24 AM
cornbinder
May 24, 2010 10:56 PM
410 Highboy
Feb 27, 2009 08:14 PM
hstormn
1978 - 1996 Big Bronco
May 19, 2004 08:07 PM
slik
Jun 26, 1999 08:13 PM
