How do I know my EGTs?
I have an 2012 F350 SRW 6.7. I tow a 5th wheel trailer. The gauges show me my trans and oil temp, and the idiot gauges show me coolant temp. But I can't find anything that shows me my EGTs? What is the best way to get this information? I don't really want to get a tuner. Is there something I can get that just shows me the information via my OBD port? I've got a big trip coming up and I know that one of the grades I will be facing is 10 degrees up hill (just outside of Jackson, Wy. Any help, guidance, recommendations, etc., would be greatly appreciated.
Ron
Ron
There are 3 EGT sensors post engine downstream. You can monitor all of them with the edge. The optimum place to get exhaust gas temp is the exhaust manifold. Since those are in the engine valley, it would be very hard to get at the good spot, then drilling a hole there for the probe would be a bad idea if shavings fell in. I am trying to tap members for info who have the edge. If the EGT gets too high, the PCM will take over and trim the fuel back until the engine cools. You have no control over that.
Thanks in advance!
Im hoping one of the resident techs tells me what temp that is. I want to set an alarm in my Edge Insight when I get 100 degrees from that number so I can take over rather than the computer. EGTs are not a problem in a stock vehicle, tuners make the EGT go high so I monitored them in 6.0L with tunes. I think the EGTs in the exhaust can get to 1100 degrees during an active regen. The only to get a good reading in the 6.7 would be to drill a hole in the manifold and insert a pyrometer probe and attach that to an analog EGT gauge or a Digital unit like the Edge product. Getting to the manifold would be very difficult and drilling a hole there would introduce shavings...very bad!
I think I understand
You still want the CTS. It gives you oil temp, transmission temps, egt's, boost and others.
You can never have too much information especially when towing a trailer.
I thought I didn't need it but I like having all that information. I know I'm in control then if anything starts to happen.
Agreed. I tow my 5th wheel toyhauler in mountains. I watch the oil and tranny temps while I am climbing so as not to overdue it, but a real monitering system like the edge, gives me the opportunity to look at many things and in the 6.7 I want to see if soot buildup is going on due to my driving habits and if the regens are working since the dang thing starts regen everytime I pull up to my house. 300 bucks is a good investment to me since I pull a heavy trailer up hills. If you tow a lot, and your curious and feel better about knowing what is happening other than oil and tranny. Edge insight is really a whole bunch of gauges and it only monitors, not tunes. It wont void your warranty. Your stock truck is fine with just the stock gauges and the PCM wont let you hurt the engine if you watch your tranny temp and oil, drain your DFCM and use a good lubricity additive in the tank.
i look at it like this: Ford built this truck to tow, and not worry about it. And not worry about EGT. Unless you have a tuned set up, you shouldnt be worrying about it. If they thought you should be, there would be provisions for it. Just like they provide oil / trans temp info. Also, the computer knows, and if a temp is out of tolerance, the trucks knows how to react accordingly. It will reduce power and tell you its pissed.
