Help! P0734 Code
Old Jun 7, 2012 | 12:30 PM
americangirl's Avatar
americangirl
Exclamation Help! P0734 Code
Hi guys! Any help is much appreciated.
1995 Ford Ranger XLT Reg. Cab - 2.3L 4 cyl. - 90,000 miles
After driving for about 10 minutes or so, the overdrive light starts flashing and then it starts to shift hard in to 1st/2nd. Also, noticed Coolant stays low. Took it to Ford and they said new/rebuild tranny - 4th gear slipping.
My bill says
P0734 code in PCM
Diag electronic trans. P0734
Overdrive band slips when hot and
would need overhaul to repair or replace.
Everything is in great shape. Overdrive function turns on/off just fine. When it's flashing, it can't be turned on/off. I typically just turn off the truck for a minute and then I'm good to go again. I've disconnected the battery to clear it out, but it's still coming on. Heard it may be more electrical than anything else, and I've read on here that it could be several things and not necessarily need any tranny work.
Any thing I can try before putting money in to a new tranny?
Thanks!
Old Jun 7, 2012 | 05:17 PM
SirArgus's Avatar
SirArgus
dont know much about auto's but if overdrive is slipping i would say you got a dying transmission. you could drive it for a long time if you dont use overdrive i guess? i would look around for a used trans and stay of the broken gear and drive it.
Old Jun 7, 2012 | 06:36 PM
pawpaw's Avatar
pawpaw
My bill says
P0734 code in PCM
Thanks!
Welcome to FTE.
Did the problem come about suddenly after some event, or have you been having shifting problems for a while????
Has the tranny fluid & filter ever been changed???
How is the tranny fluid condition & fluid level????
Old Jun 7, 2012 | 07:00 PM
americangirl
Originally Posted by pawpaw
Welcome to FTE.
Thanks!
It actually shifts like a champ! Both shops said the trucks in great shape. Recently had a transmission flush and fluids are good. They just got checked. The filter I'm almost sure was changed too.
Can probably use some new spark plugs but they said I can wait a couple months on that.
Thanks again!
Old Jun 7, 2012 | 08:02 PM
pawpaw's Avatar
pawpaw
Did the problem come about After the tranny flush service????
Most tranny flush routines Don't include a pan drop & filter change, we have to request & pay Extra for it!!!! Look on your service reciept to see if a tranny filter is listed.
Edit: Forgot to add this link: Check or have the things listed checked. http://engine-codes.com/p0734_ford.html Let us know what you find.
slfd1717
Apr 7, 2013 08:02 PM
rbsample
Feb 3, 2011 01:04 PM
highboy
Dec 2, 2007 09:10 AM
crosscountryranger
Sep 12, 2006 11:09 AM
pancartom
May 6, 2003 08:52 AM
