General questions
1) Where did the "bump" in bumptruck come from? The ridge running down the side?
2) I know the brake (warning?) switch activates that little light in the lower left of my dash, I have the bulb and I do have the switch on my very grimy proportioning valve. What exactly does this switch do, how can I see if it still works ( it isn't currently coming on) and do I really even care?
3) Where does the backup light switch mount on a 3 speed columnshift truck, I do not have backup lights.
Other projects this weekend are a complete overhaul of the cooling system since the thermostat/radiator flush didnt do the trick.... A few other small jobs, then it goes to the mechanic to iron out problems in the carb, tranny, and steering column.
Then, finally, she is fully road ready and it's time to start working on appearance.
What is the concern with the cooling system?
John
C8AZ-2B264-A .. Low Brake Fluid Warning Lamp Switch / 1968/79 F100/350, Bronco & Econoline / 1968/69 all FoMoCo Passenger Cars / 1970 Maverick before 7/14/1969.
Both of these little charmers thread into the proportioning valve and both are terds. These switches are plastic, develop cracks in their threads, which causes brake fluid to seep out.
When this occurres, the low brake fluid warning lamp on the dash comes on...and stays on. Some peeps disconnect the wiring harness at the switch, so the lamp will stop glowing.
C9TZ-15520-A (Motorcraft SW-938) .. Backup Lamp Switch 3 speed manual & 3 speed O/D. Attaches to a bracket on the steering column, under the hood, adjacent to the 1st/reverse manual control selector lever.
Backup lamp switch with: New Process 435 & Warner T-18 4 speeds threads into the shift tower. The switch used 1967/68 is different than 1969/72.
1967/77 F100/350 with A/T. The backup lamps are controlled by the Neutral Safety Switch: C7TZ-7A247-A (Motorcraft SW-600).
Note: These trucks were available with a dealer installed accessory Park (emergency) Brake Signal Lamp (C7TZ-15A852-A). This is not the same as the low brake fluid warning lamp.
As for the brake fluid switch, I am going to clean the proportioning valve and unless I see leaking, I am leaving it be.
I will be checking the circuit on the backup light this weekend.
Joe, as far as the cooling system goes. It still is getting hot and I have already done a flush and changed the thermostat. When I did the flush the radiator still had a lot of corrosion in the core. I changed the heater block off valve that was corroded in the open position and the amount of rust lining the hoses Concerned me about putting a new radiator on just to have it clogged with old loose rust. Like I said in this or another post this truck sat up a WHILE in the past, I have found acorns sitting on the intake and birdsnest in a fender and headliner. Also, I already have a reman water pump that I might as well put on, it doesn't do me any good looking pretty in the box. I also need to put a shroud on.
So, this weekend the whole deal goes on. New radiator, shroud from salvage, water pump, new hoses, new clamps on corroded old ones. I am also installing a 10" electric fan as a pusher fan in front of the radiator behind the grill. This is a daily driver for me, and I go to law school in downtown Fort Worth, so I want the extra for those long stop/go drives in Texas heat. Just for looks painting the radiator top, water pump, and underside of hood with the ford blue engine paint.
I am curious if a shroud would take the paint as well...
John
Also, I used to use cheaper antifreeze but I spent enough on this job that I spurged for prestone. I am guessing the system will take 5-6 gallons of fluid, so I bought 3 gal unmixed antifreeze & then the water.
on.So, this weekend the whole deal goes on. New radiator, shroud
from salvage, water pump, new hoses, new clamps on corroded old ones. I am also installing a 10" electric fan as a pusher fan in front of the radiator behind the grill. This is a daily driver for me, and I go to law school in downtown Fort Worth, so I want the extra for those long stop/go drives in Texas heat. Just for looks painting the radiator top and underside of hood with the ford blue engine paint.
There are two different fan shrouds, they do not interchange! One is only used with the Super Cooling radiator and its specific radiator support.Fan shrouds have their specific ID number molded into the fibreglass, left (drivers) side upper corner.
1967 F100/350 352 / 1968/76 F100/350 360/390:
D3TZ-8146-C (replaced C8TZ-8146-K) .. Fan Shroud-Use with standard, xtra cooling & A/C radiators / Marked: D3TA-DA or C8TA-S
C7TZ-8146-B .. Fan Shroud-Use with Super Cooling radiator only / Marked: C7TA-8146-H or D2TA-8146-HA or D3TA-8146-JA
Standard, xtra cooling & A/C radiators: 24 1/4" wide x 19 1/4" high // Super Cooling radiator: 24 1/4" wide x 24 1/8" high. Super Cooling radiator has a HUGE top tank, overlaps the core and is wider than the other radiators.
Since the Super Cooling radiator is higher than the other radiators, its radiator mounting flanges are in different locations, so uses a specific radiator support and fan shroud.
ND, The new radiator I just bought is currently high gloss black, the remanufactured water pump is unfinished iron, and the shroud is gray.
The shroud is from a newer Ford, but the radiator size appears either the same or really close, the diameter for the blades is right size and appears to be properly positioned when I sit it on top of the new radiator on the ground. I will have to fab up a bracket, and it may turn out to not work and in that case no shroud for me... I simply cannot afford the new ones right now. I chose to buy the new good metal radiator and try to salvage the shroud instead of going salvage radiator or buy the cheap plastic tank replacement radiators the parts houses are pushing.
I realize that I might be going hog wild with the color, but I have seen the engine bays color matched and I personally like it. Having a color theme kind of makes it more of a project and less of putting band-aids on the prior owners mistreatment. I also like going crazy with chromed parts but the budget doesn't like that at all, so it's rattle can customization for me.
Part of it may be that the engine bay is the only area I can afford to pretty up anytime soon. The bed/interior/body parts and paint is going to cost a fortune. I would probably be less inclined to go paint crazy if almost all of the color was already changed from original anyway. Right now the exterior is that primer black that I am almost certain was a rattle can job and the interior how has a tan seat I robbed from a 70s Ranger. The seat in it when I purchased (black) was unsafe it would slide forward when you hit brakes, and springs ripped clothes.
Sorry for the long post, I am pi$$ed off. While I was tinkering on the truck tonight I got the wild hair to go vacuum all the wire trimmings and junk from the recent electrical work from my floorboard and spray out the rust chips from the bed. I was at the car wash about an hr and I come home to my apt, some jerk has jumped over the rail and stolen two of the jugs of antifreeze off the patio. Almost $40 gone, but what really bothers me is my wife was home asleep just on the other side of the glass. I hate my apartments more every day...
I can't cook, hell I can barely boil water, so was totally unprepared. Guess I'll have to pig out on fast food till she returns.
How's the weather in the Dallas/Ft. Worth metro-plex, hotter than a popcorn phart? Serves her right if it is.
Well I am off to O'Reilly to buy more antifreeze and some more electrical components. I am repairing the trailer light setup on the truck today. Prior owner did have a light pigtail but i didnt orginally know it was so tangled in twine and duct tape... I had already bought and opened the new one so its going on. Also, My bumper has a spot for the old round trailer light that has been long ago cut off and is corroded, I am thinking of running a weatherproof cigarette lighter port like used on boats so I have a handy plug for tailgating and such. Gets the corroded part out and makes use of the hole at same time.
Anyway, hope you don't starve over there in Sunny CA.
John
