Fuel Injectors
Old Jun 6, 2012 | 06:23 PM
brandon.edwards's Avatar
brandon.edwards
Fuel Injectors
Hello diesel friends.
I have all the signs of bad injectors, and now its all up to a diagnose which injectors are bad. First off, how do i do that without a programmer? IS there a way to find which ones are bad? a free scanning method? Second of all, I have seen so many types of injectors and I dont know which ones to pick. I dont run my truck hard so I was thinking to just get as close to OEM as possible. Lastly, keeping the injectors maintained, is it as simple as keeping my oil changed every 3,000 miles and an additive? Any thoughts?
Thanks in advance.
Old Jun 6, 2012 | 06:47 PM
Flyinstroke's Avatar
Flyinstroke
OEM injectors are the best way to go and beleive it or not (at least from my recent purchase) Ford was the cheapest place to get them.
Old Jun 6, 2012 | 07:13 PM
69cj's Avatar
69cj
Did you test the ficm? That can seem like bad injectors.
Old Jun 6, 2012 | 07:20 PM
Piolet's Avatar
Piolet
Thanks in advance.
Welcome to FTE.
If you can swing it you should get a Scangauge II or an Edge Insight. Both are electronic gauge readers that are pretty much plug and play.
They also read some codes too. They will read the FICM volts and let you know if that is an issue, and not the injectors. That alone could save you a lot of cash.
I personally could not imagine owning this truck without one of them if you have a plan to save money and do repairs yourself.
Scangauge II $160
Edge Insight CS $270
Edge Insight CTS $350
Best money you will spend as an owner of a 6.0
Old Jun 6, 2012 | 07:55 PM
brandon.edwards
69cj- I haven't tested anything yet. I just know that i cant ever just hop in and take off in my truck. Its dangerous, because i cant get any speed. I have to let the truck warm up even on warmer days. Then she drives like normal.
piolet- Thanks for that great information! where did you get yours?
flyinstroke- Your kidding Ford is the best way to go!? Never thought id see the day!
Thanks for the great help!
Old Jun 6, 2012 | 08:06 PM
Piolet's Avatar
Piolet
I went for the Edge Insight CTS .... but I like gadgets and it has a whiz bang touch screen with the ability to plug in a $20 camera and get reverse monitor capability.
I see it's now on Amazon for $360 with free shipping. That's a good price.
Amazon.com: Edge Products 83830 CTS Insight Monitor: Automotive
The CS is not touch screen but still looks modern.
The Scangauge looks very 80's but it has about 3 or 4 things it can read that the Edge doesn't display ... IPR and some of the FICM stuff.
I also own a scangauge but I prefer the CTS. I choose it over the scangauge everytime*
*my personal preference. I know some guys love their scangauge so to each their own.
Old Jun 6, 2012 | 08:15 PM
Piolet's Avatar
Piolet
What you have to understand is that all the stuff on this truck is interconnected and it can still start and run up to a point where something fails. The path to that failure many times will not be shown by the factory gauges and the path usually ends at the most expensive part in the food chain.
One example -- your batteries may be underperforming during start up. Nothing on the dash will tell you this. The truck will still start and run, may be some trouble but not enough to raise concern. Those underperforming batteries will be placing a strain on the FICM, which is trying to kick out 48 volts from batteries that may be providing 9v on crank. The FICM becomes damaged which can be a $900 repair at the dealership or $300 from one of the sponsors on here.
That FICM can also then take out your injectors and that's where the big bucks come in. All that could have been prevented by noticing on your Edge that the batteries were dipping into the 9's on start up and allowing you the chance to replace just the batteries.
Old Jun 6, 2012 | 08:18 PM
brandon.edwards
Wow i never thought of it that way.....Im going to be getting the scangaugeII
Old Jun 6, 2012 | 08:32 PM
brandon.edwards
Will the scangauge II tell me about injectors? ficm? and so on...
Old Jun 6, 2012 | 08:36 PM
tex25025's Avatar
tex25025
The Scangauge II from my understanding will only let you know about the general powertrain with regard to codes. If you want more indepth, you are going to want something that can read all 9 modules.
I actually prefer the DashDAQ with the Ford License, but that isn't the budget friendly gadget.
Piolet's Avatar
Piolet
Use the search function at the top of the page. Search for "scangauge" in the "titles only" and choose the "6.0 diesel forum".
Trawl through what ever comes back. Pay attention to posts by members 'BLADE35' or 'amdriven2liv'. They are both power users of the scangauge and have posted tons of info on the gauge and what to look for, how to set it up etc.
Old Jun 6, 2012 | 10:09 PM
Roasted7's Avatar
Roasted7
You will need to do a contribution balance test with diagnostic software.
None of those scanners will work worth a crap for what you need.
Old Jun 6, 2012 | 10:14 PM
tex25025's Avatar
tex25025
Most of the time a bad injector will throw a contribution code. Any scanner that reads manufacture specific codes will pick that up.
Old Jun 6, 2012 | 10:16 PM
Roasted7's Avatar
Roasted7
Never got any codes on my truck but definitely had bad injectors.
Old Jun 6, 2012 | 10:18 PM
Piolet's Avatar
Piolet
I think the point is he may have nothing wrong with his injectors at all. A simple gauge could show his FICM is the only problem.
