K&N CAI V.S. Stock
K&N CAI V.S. Stock
Ive Read alot of fourms and Alot Of people Saying That On open element is Worse then Stock. Mileage and Perforance Wise and others saying that stock is better. I Bought a Open element And im going to test and document Starting with stock setup Then Put the K&N on. And Ill Get Back and Let yall know The results
I use the K&N on my 92 F150. I like the power gain and the sound. The truck has always been a gas guzzler do to the design. I want to put a Mass Air conversion kit on my truck to help with gas mileage and swap out the 302 with a 351 for more power gains....Other then that I recommend the K&N filter kit. I have had the kit on my truck for nearly 10 years and still looks new when I use the recharger kit to clean the filter. It has a life time warranty also if that helps on your decision.
I want the Ram-Air hood and Kit for my truck. I like the looks of it.
Good luck to ya!
Good luck to ya!
I'm using the stock air box with the 300/460 tube and a Motorcraft filter. This setup works the best. I've had regular KN replacement filters and their open element hot air intakes. All I can say is I'm done with wasting money on that junk. If I ever was to get a so called performance air filter again, it would be a non oiled type.
BumpDraft2007
1997-2006 Expedition & Navigator
15
07-29-2010 03:24 PM
Skandocious
36
10-04-2007 11:26 PM
