When it rains, it pours
Old Jun 3, 2012 | 05:11 PM
motopsyko32's Avatar
motopsyko32
2000 Ex 5.4 v8
Had 2 coils go bad last week. Got them replaced. Today I am on the turnpike doing 70 and my oil light comes on and oil pressure drops all the way.
No engine noises and temp is OK so I coast to the next exit. Get off and go to the gas station in the corner. Turn the truck off...
Wait a few minutes, when I go turn it back on it wont start. Th motor wont even turn. It just clicks.
I notice smoke coming from the wire that goes from the starter relay to the starter so my brother comes and gets me and we go to the nearest auto part store and buy a new relay.
Replace it and try to start it, same thing. Just clicks and smoke.
My brother gets under the truck and taps the starter as I try to start it, no go.
I am fearing the engine locked up. But no engine noises, clicks or clacks or anything.
Battery is fine as well.
Any thoughts on what else I can try?
Old Jun 3, 2012 | 05:59 PM
motopsyko32
this son of a bitch just started ..... MOTHER F'er...
But now I have a slight knock on idle only. As I accelerate it goes away.
Old Jun 3, 2012 | 06:06 PM
tims01's Avatar
tims01
super sad face ...
Old Jun 3, 2012 | 06:21 PM
motopsyko32
not so much sad as its a material thing that can be fixed or replaced, just upset stomach thinking of the mechanic bill to come.
Old Jun 3, 2012 | 06:23 PM
tims01's Avatar
tims01
this is true .... wel time to go buy a cummins motor to put in it .... oh lookey happy face
Old Jun 3, 2012 | 06:35 PM
motopsyko32
LOL... I will stick to gasser... if I do have to replace motor it will be a crate motor...
Old Jun 3, 2012 | 06:37 PM
motopsyko32
Anyone else?
Old Jun 3, 2012 | 07:38 PM
Snowseeker's Avatar
Snowseeker
Did you check the oil during any of this?
Old Jun 3, 2012 | 07:50 PM
motopsyko32
so yes, forgot to mention that, Checked oil as soon as I got off the highway and the dipstick had a tiny bit at the end only. Let it cool and remeasure and still just a tiny bit at the end. Bought some oil at the gas station and put in 4 qts. Checked dipstick and now oil was at max. Got home and when it FINALLY started I turned it off and let it sit for a bit. checked the oil and now it is WAY past max. Will need to drain some tomorrow.
Old Jun 3, 2012 | 10:43 PM
jh818's Avatar
jh818
I would give it a full oil change...that way, you'll know for sure how much oil is in there.
Old Jun 4, 2012 | 12:26 AM
EXv10's Avatar
EXv10
Sorry but I think you are beyond oil changes at this point. The fact that it was at max on the stick after 4 quarts installed tells me that it was 3 quarts low. Those dipsticks can be tricky, wipe it clean, put it in 3/4 of the way then quickly bottom it out and pull out quickly. Pistons can seize when they get no oil and lock the engine until they cool down. If you EVER see the oil light come on and the gauge drop to zero shut it down right away and hitchhike to get some oil if you have to. The reason your starter cable smoked was because the engine was temporarily locked up and the starter was trying to turn over a locked motor. I'm guessing at least one seized piston, drain some oil out so it fills about an inch in a pan, then look at it in the sunlight for aluminum flakes (like you are gold mining). Good luck and get back to us.
Old Jun 4, 2012 | 12:29 AM
tims01's Avatar
tims01
mmmm crate motor
Old Jun 4, 2012 | 01:59 AM
Monsta's Avatar
Monsta
Sit. Stay.
Maybe you should drop in a V10. You'll just need a computer and a couple extra COPs...and wiring...and gas.
Old Jun 4, 2012 | 02:09 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
No extra gas required lol. Thats my only gripe about the 5.4 in a SD (or EX). Same mileage, less power than a V10
Old Jun 4, 2012 | 06:16 AM
motopsyko32
I had the v10 ex before. Sold it and got the v8 a few months later. Will check oil for flakes.
