1978 - 1996 Big Bronco
1996 5.0l ????
Old May 6, 2003 | 07:44 AM
teflon_80's Avatar
teflon_80
1996 5.0l ????
This is a good question I think. I own a 1996 Ford Bronco (full size of course) with the 302 and I am in an interesting predicament. Everything I can find for a 302 is for model year 1995 and earlier. Is this the same motor and will the 1995 parts work on a 1996? I know the Mustang started the 4.6 in 1996 so I thinking that may have something to do with it. But I would like to change the Cam, Intake and some other parts but don't want to waste money on things that won't work. Any help anyone can render would be great. Thanks fellas.
Old May 6, 2003 | 08:15 AM
WhëëlMå1's Avatar
WhëëlMå1
1996 5.0l ????
Welcome to the wonderful world of our 96s. I have a 351. I have found all sorts of stuff for the 96, I just had to do some snooping. I believe OBD-II started in 96. Most manufacturers and distributors kind of forget about this year. If you call your local power shop, or these online retailers, and tell then what you have, they will have something for you. What kind of stuff in particular are you looking for, and have you done any online searching yet? If you have specifics, you can drop me an email or just post it here and I can help you out.
Rich
Old May 6, 2003 | 08:23 AM
steve83's Avatar
steve83
1996 5.0l ????
The trick is that it's an OBD-II MAF engine, so the wiring is different, and so are a FEW of the parts.
What are you looking for?
Old May 6, 2003 | 08:46 AM
teflon_80's Avatar
teflon_80
1996 5.0l ????
I've been looking for a new intake. I would like to put in a gt-40 intake but i'm not sure if it will fit. Also new heads and a cam if possible I found a lunati truck cam that I think will work I just want to make sure that everything fits.. I've done the exhaust (headers) already but i would like to do some intake parts as well. (MORE POWER!!!) Thanks for the replays, hoping to hear more good stuff.
Old May 6, 2003 | 09:54 AM
WhëëlMå1's Avatar
WhëëlMå1
1996 5.0l ????
Have you checked out motorhaven.com yet? They might have some stuff for your application.
You might also want to take a look at www.proficientperformance.com All they do is the induction side of performance. Bunch of knowledgeable guys too. As for the cam, I would call Lunati directly, or any of their distributors to make sure it will work. What are the specs on that cam?
Rich
