Testing servo throttle body
Old Jun 2, 2012 | 03:04 PM
travlnman's Avatar
travlnman
I have a 2010 F150 4.6L 2V , with the servo throttle body. Does anyone have a procedure to test this with an ohm meter ? I believe it uses dual signals, one a zero to +5v signal, and the other a zero to -5v signal, but not sure of the pin configuration. I could go by trial and error, but was curious if anyone knew the answer first, or where I could find the answer. Thanks in advance for your help.
Old Jun 5, 2012 | 11:19 AM
royb's Avatar
royb
if it is not working correctly it will throw a code.
you have a drive by wire system (no cable) so the voltage changes all the time to bring about the desired result.
doctisdall
Jan 9, 2022 06:08 PM
makuloco2000
Transit Connect
Jan 20, 2014 10:46 PM
