Modular V10 (6.8l)
help!
Old Jun 1, 2012 | 06:10 PM
aidensdaddy's Avatar
aidensdaddy
help!
I have a 1999 sd v10 4x4. it has about 150k on it. this problem has started about a month ago. while in park, it idles kind of rough but not bad. but while in gear, it idles horrible, shaking and even lunging the truck. it even stalls out most of the time if i dont throw it in neutral at a stop light or something like that. i have replaced 3 coils and went trough the other 7, replaced the egr valve, and the pcv valve and also changed the plugs about 200 miles ago. put a computer on it, and all it said was bank 1 and bank 2 lean. took negative cable off for 5 minutes, and it hasnt changed a thing. i just ordered an idle control valve, but was wondering if this truck even has one on it. any ideas? please help. i have limited funds available to me.
Old Jun 1, 2012 | 07:37 PM
V10ZILLA's Avatar
V10ZILLA
Injectors can go bad as well. Just because you change out the coils the injectors can go bad.
Not that this would trip lean banks but a clean/new fuel filter could not hurt.
Really the only thing that I could think of is injectors at this time.
Just wait for a while or until the weekend is over, you will get some people to chime in who maybe have had this happen to them as well. You will get it fixed. just wait a bit.
Old Jun 1, 2012 | 07:57 PM
aidensdaddy
it only does this at idle. when driving down the road, it runs great. im just at a loss for this at the moment.
Old Jun 1, 2012 | 08:57 PM
mikeismadness's Avatar
mikeismadness
Sounds like your IAC is shot.
Old Jun 1, 2012 | 08:58 PM
mikeismadness
Clean your MAF sensor with MAF cleaner also :-)
Old Jun 1, 2012 | 09:29 PM
aidensdaddy
i read in another post about this engine, but a newer one, that they didnt have IAC. I was wondering if this year even had one on it. and i will clean it asap and let yall know if it helps
Old Jun 1, 2012 | 10:00 PM
jh818's Avatar
jh818
Yes. Yours has an IAC valve...or should. It's not a drive by wire.
Old Jun 1, 2012 | 10:58 PM
aidensdaddy
Where is it located exactly?
Old Jun 2, 2012 | 03:46 AM
Aune163rd's Avatar
Aune163rd
*subscribed* I want to learn too, I have a 2000 SD V10...
Old Jun 2, 2012 | 07:03 AM
aidensdaddy
the way im hearing it, the 99 -04 are the same styles? meaning all or most parts inter - change? is this correct?
Old Jun 2, 2012 | 08:59 AM
jh818's Avatar
jh818
Yes, that is correct. I know for a fact that the alternator is not the same between 00 and 02. Also the turn signal switch was different from 02 and up.
Old Jun 2, 2012 | 05:55 PM
aidensdaddy
changed the idle air control, and cleaned the mass air flow sensor, helped a little, but not much. any more ideas?
Old Jun 2, 2012 | 06:57 PM
jh818's Avatar
jh818
Check for vacuum leak in the elbow for the PCV valve.
Old Jun 2, 2012 | 11:10 PM
shadows4's Avatar
shadows4
X2 Thats what I would have looked for first.
Old Jun 2, 2012 | 11:52 PM
jh818's Avatar
jh818
Be sure to disconnect the negative terminal of your battery for 30 minutes to clear the computer so it relearns your driving pattern.
