Truck talking?
Old Jun 1, 2012 | 05:44 AM
bigtwinharley's Avatar
bigtwinharley
Truck talking?
Good morning all
Ok so I keep forgetting to post this. Does anyone else's hear their trucks computer talking on the outside of the truck. As I walked outside this morning I heard it again in the garage. Not sure if it's the sync talking to itself or what is going on. It's not voices or anything like that lol. *
No keys in my hand have not unlocked the doors nothing just walking by the truck. *Have not touched the truck*
2011 diesel 6.7
Thanks for the input
Old Jun 1, 2012 | 09:03 AM
kper05's Avatar
kper05
The only way I can describe it is a "meep" noise (it's not a beep).
Is that what you're asking about?
If so, it comes from the transmission pan.
While it's not normal in my opinion, it's normal to FoMoCo.
I don't know what it is and I've had the solenoid replacements.
Old Jun 1, 2012 | 10:41 AM
Andrew010's Avatar
Andrew010
These trucks make more noises when they're aren't running then when they are running. There's half dozen different noises my truck makes after it's been turned off. No idea what it all is and it's done it since day one. Took some getting used to, that's for sure.
Old Jun 1, 2012 | 03:17 PM
lundman's Avatar
lundman
truck talking
Call 1-800- exorcism. I've heard of people talking in their sleep but not trucks. My truck doesn't talk unless I use sync. Sounds like a great horror movie though.
Old Jun 1, 2012 | 04:20 PM
Tuxedo Scorpion's Avatar
Tuxedo Scorpion
my truck talks to me. it says stuff like "liiiiiift meeee", "biiiggggeer wheeeels", "tiiiitaaaan siiiixty fiiiiive gaaaalllon taaaank", "toooooow sommmmething"
and so on...
Old Jun 1, 2012 | 04:36 PM
Andrew010's Avatar
Andrew010
It should tell you to install rear wheel steering so you can actually turn that thing in parking lots.....
Old Jun 1, 2012 | 04:37 PM
Tuxedo Scorpion
skills overcome gimicks any day..
Old Jun 1, 2012 | 09:29 PM
cabindoc's Avatar
cabindoc
Now we know why some guys get SB's....
Old Jun 1, 2012 | 09:35 PM
Tuxedo Scorpion
Oh btw theres a device installed at the factory to help with that. Its right in front of the driver seat coming out of the dash and has a round shape. It connects to the front wheels so when you manipulate its function it activates the front wheels such that they change anglular position thus taking the vehicle in various directions.
Old Jun 1, 2012 | 09:41 PM
cabindoc's Avatar
cabindoc
Isn't there a screen on the dash that tells one what angle the tires are turned? sorta like that gauge on a plane, what's it called??? Rudder position indicator thingy..
You know we are just bustin on you Andrew, right?
Old Jun 1, 2012 | 11:04 PM
Andrew010's Avatar
Andrew010
It's ok Scott, I already knew Jason was overcompensating for something. I now realize you are as well....
Old Jun 1, 2012 | 11:19 PM
Tom's Avatar
Tom
What's that, the factory rubber band tires?
My truck made lots of noise when it wasn't running, but that was always after it was shut off. Not sure what it could be doing after sitting for awhile, but this could be an issue with draining your batteries. If you get the chance you could hook up an ammeter in line with the batteries to see how much current is being pulled by the chatter.
Old Jun 1, 2012 | 11:32 PM
mbovinet's Avatar
mbovinet
Mine also "meeps' so to speak
Old Jun 2, 2012 | 05:42 AM
Tuxedo Scorpion
mine meeps until the accessory delay turns off then its quite as can be
Old Jun 2, 2012 | 12:46 PM
Rick Cargo's Avatar
Rick Cargo
Same here, 'meeps' when you open the door and it 'meeps' when the parking lights go off. But every now and then it will 'meep' after its been sitting and turned off after a couple of hours.
