cold idle question
Old May 5, 2003 | 09:01 PM
daspud's Avatar
daspud
cold idle question
hello , is it normal for idle to be at 1400 to 1500 rpms and stay there for about 45 seconds to 1 minute after engine is started cold. after that time span it does drop to normal. idle air valve is new with no change also no codes set thanks 94 5.0 with mass air . maybe its just the way it works?
Old May 5, 2003 | 09:40 PM
steve83's Avatar
steve83
cold idle question
That sounds a little high - did you unplug the battery to clear the adaptive strategy? Did you read this thread?
Old May 5, 2003 | 10:01 PM
lexluthr69's Avatar
lexluthr69
cold idle question
Sounds very normal to me. My '89 F-150 5.0L does the EXACT same thing. If it isn't normal then I guess I need to know what my truck has been doing wrong for the past 13+ years.
Once it is warm, does it only take about 15-20 seconds to drop back down to normal idle?
Luke
