fuel problems
Old May 30, 2012 | 09:49 PM
jeremy_cs's Avatar
jeremy_cs
fuel problems
I have 88 f250 with dual tanks..The truck runs perfect on front tank.. i switch to the back tank the truck will run 5 min and then quits..Pressure at the rail is 0.. The fuel pump in back tank was replaced..But i can switch to front tank crank and it will run perfect.. any ideas as to why it wont run on back tank??
Old May 30, 2012 | 10:18 PM
jimogeek's Avatar
jimogeek
F1UZ-9B263-B Fuel Tank Reservoir Switching Valve Fits F150/F250/F350
I feel your pain. Went through something similar. It COULD be the rear low pressure booster pump, but probably not if you replaced it. The high pressure pump gets fed downstream from the Fuel Tank Res. Switch. I suspect your res. switch is bad, not allowing fuel to make it from the rear tank to the pump and fuel rail. From what I've read, bad o-rings and various other things screw up the fuel flow, and check valves, my particular problem was the rear tank filling the front tank and lower rail pressures. You can test by removing the supply and return lines from the rear tank to the switch and bypass it straight to the pump, and see what happens. I had a similar problem and replaced the switch tonight, truck runs better and my fuel pressure went from about 30 to 40-43 PSI. Bought the overpriced thing on ebay, expect to pay at least $170-180 bucks for one. I've got an 88 250 as well, our switching valves are mechanical, not electrical, and they only used it on a few years hence the higher price due to scarcity.
predaina
29
Mar 29, 2011 07:07 PM
dads red truck
Oct 21, 2010 12:10 PM
driller tom
Jul 16, 2010 11:20 AM
ncguy23
22
Jul 21, 2007 09:49 PM
Fluorspar1
Jun 26, 2003 11:59 PM
