need advice aqnd recomendation
Old May 29, 2012 | 12:41 AM
cws10190's Avatar
cws10190
any body have any ideas on how to clean these up like new? they r aluminum and i want the clear coat off.
Old May 29, 2012 | 12:44 AM
montana_highboy's Avatar
montana_highboy
Old School Aluminum Slotted Mag Wheels - Extreme Makeover - Auto Geek Online Auto Detailing Forum
Old May 29, 2012 | 12:50 AM
gpence's Avatar
gpence
go down to the nearest truck wash shop & have them spray some alum-A-shine ( spelling?? I'm to lazy to walk out to the garage and check) it's acid wash for semi wheels & fuel tank's on them or sand blast them. I blasted my turbine's with my wet sand blaster and they turned out pretty good but make sure you use a fine sand so that the sand don't pit the aluminum
Old May 29, 2012 | 10:43 PM
Blythewoodjoe's Avatar
Blythewoodjoe
What ever you use, I would suggest testing it on the back of the wheel first. I remember once using some cleaner on the engine of our 86' 5.0 mustang and it turned the intake gray. That sucked.
Old May 29, 2012 | 11:18 PM
gpence's Avatar
gpence
any of the wheel/aluminum wash's that contain acid will turn them white after a couple days unless you hit them after they dry with some kind of polishing compound
schoo
May 29, 2012 07:51 AM
65fordguy
Appearance & Dress-Up
Oct 24, 2011 11:33 PM
65fordguy
1978 - 1996 Big Bronco
Oct 20, 2011 09:35 AM
Tees77f150
Jun 13, 2010 09:45 AM
Damon_Tirerack
Aug 18, 2009 03:07 PM
