351 swap
Old May 5, 2003 | 05:04 PM
motorhead_83's Avatar
motorhead_83
351 swap
I am swapping a Carbed 1970 351W into a 1990 F-150 that had an EFI I-6 in it. Trans is a 4 speed manual with granny 1st.
Will 302 Accessorie brackets for alt. ps. and ac. work on the 351?
Will the output shaft of my trans(stock 4 speed manual with granny 1st) fit to the 351(came out of an LTD or Torino.. not sure which, but it had an auto trans)?
Old May 6, 2003 | 10:54 AM
red_rocket's Avatar
red_rocket
351 swap
the tranny will bolt up, but the you will need a new flywheel and clutch assembly.
As for the accessorys, Im unsure.
Old May 6, 2003 | 10:59 AM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
351 swap
I did a similar swap - I made the alternator bracket work, and had to modify the power steering pump bracket by cutting it in half and adding about 1" of steel. The windsor is a little wider, and since the power steering pump has a bolt that goes to the head, I cut the bracket, bolted it to the waterpump, then hung the pump from the head, clamped in a piece of steel, tacked it, took it all apart and brought it over to my welding table where I welded it but good!
Those are the only two accessories I run, so am unsure of any other bracketry.
Old May 6, 2003 | 11:04 AM
red_rocket's Avatar
red_rocket
351 swap
Wow, Dan, I just noticed you are also In hougton! I'm here for college(going back to MN friday) Maybe you have seen my F-150 in town? Its red, with a black roll bar, about 5" lift and 35's?
