Offroad & 4x4
03 explorer sas
Old May 27, 2012 | 08:36 PM
joestn89's Avatar
joestn89
03 explorer sas
My parents have an 03 explorer an the tranny is about to go. So i was thinking about sas it. It has independent suspension all the way around and the frame in the back is weird. So anybody ever done anything like this? I know the frame would have to be modify but dont Know where to start.
Old May 28, 2012 | 06:45 AM
77mud's Avatar
77mud
start with some axle's... goin to sas both front and rear if its Independent all the way around?
8.8 rear d44 front? or something like a D30 out of a Jeep? what size tires are you planing on running??
Old May 28, 2012 | 08:09 AM
alpha/omega's Avatar
alpha/omega
Eb axles (44/9") would be perfect on width but they are becoming pretty tough to find and rather expensive. The next best thing would be 73-79 150 axles (also 44/9") but they are a good bit wider than your Exploder.
Not sure id waste my time with swapping in jeep axles.
Old May 28, 2012 | 08:18 AM
tjc transport's Avatar
tjc transport
i ain't rite
one problem i can see with swapping an older rear axle in it would be the loss of the soeedometer due to no VSS in the axle..
Old May 28, 2012 | 09:21 AM
alpha/omega
Very true. Use a 8.8 instead of a 9". Marginal strength difference with tires 35" or smaller
Old May 28, 2012 | 09:45 AM
tjc transport
i ain't rite
didn't Josh do a SAS in his mountaineer last year??
Old May 28, 2012 | 10:25 AM
alpha/omega
I know he wanted to. Not sure if he did.
I guess im forgetting the exploders should have an 8.8 already but im not sure when Ford changed the bolt pattern to metric
Old May 28, 2012 | 12:34 PM
77mud's Avatar
77mud
he said it had all 4 corners independent though...
Old May 28, 2012 | 02:15 PM
alpha/omega
Missed that
Old May 28, 2012 | 02:23 PM
77mud's Avatar
77mud
Yea it stumped me i thought they were still putting solid axle's in the rear
Old May 28, 2012 | 02:29 PM
joestn89's Avatar
joestn89
ya its independent all the way around what ever axles i use i plan to buy a set of axles or buy a whole vehicle (70's Ford). But i don't know how to modify the frame in the rear, or should i use a entirly different frame. I will try to post some pics later.
Old May 28, 2012 | 02:51 PM
alpha/omega
Im sure it can be done with your existing frame. If you get into needing/wanting a different frame you might as well sell the exploder and but a 4wd truck
Old May 28, 2012 | 08:07 PM
joestn89's Avatar
joestn89
here a pic of the frame with the axle shaft going though it. if i cut the bottom of the circle out and flattened it it might work. Suggestion are always welcome. im only worried about wheel travel.
Old May 28, 2012 | 09:55 PM
alpha/omega
Picy no worky
Old May 28, 2012 | 10:22 PM
GNR22's Avatar
GNR22
I've seen explorers with SAS. Your best bet would be Little Bronco Axles. NOT Bronco II. Little Bronco.
