Sponsored by: Real Truck
guage cluster problem, need help!!
Old May 27, 2012 | 10:55 AM
DaneJones074's Avatar
DaneJones074
the speedometer, gas, and all that was in the guage cluster stopped working. i have been using a bully dog to determine my speed and judge how much gas i have left. and as a result of this the oil temp wasnt working so my motor had locked up. putting my new motor in soon and i need to know how i could fix this, i think it is a short in a wire because the fuse blows everytime i pull back on the shifter. anybody else have this problem?? and know how to fix. thanks!
Old May 27, 2012 | 01:45 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Welcome to FTE, Dane. If you'll give me a little more info on your truck's model year and which engine we're talking about I'll be happy to move your question to the appropriate technical forum.
Old May 28, 2012 | 04:17 PM
DaneJones074
thanks, its a 2002 F250 with the 5.4L v8
Old May 28, 2012 | 11:08 PM
SteveBricks
FTE Emeritus
OK, we'll get you some help here in the Super Duty forum
Old May 29, 2012 | 11:00 AM
DaneJones074
thanks man! hope to hear back
Old May 29, 2012 | 12:24 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Originally Posted by DaneJones074
the speedometer, gas, and all that was in the guage cluster stopped working......fuse blows everytime i pull back on the shifter. anybody else have this problem?? and know how to fix. thanks!
On the 7.3 models, these symptoms are due to a short in the Overdrive cancel button harness. Here is a link. Not sure if it applies to your engine type but it's worth a shot.
https://docs.google.com/viewer?a=v&p...M2Q5YjdmODQ4NQ
(I hope this link works...)
Old May 29, 2012 | 04:04 PM
DaneJones074
that looks like thats what the problem is, im gonna try it tomorrow morning when i go to the shop. thanks man i appreciate it! ill let you know how it goes
Old May 29, 2012 | 07:28 PM
hogryder007's Avatar
hogryder007
"and as a result of this the oil temp wasnt working so my motor had locked up."
I'm curious about this part...The dipstick is for checking your oil, not the oil temp gauge.
Old May 30, 2012 | 05:57 AM
nogo73's Avatar
nogo73
from Everything I have looked at oil pressure gauge on stock cluster only tells you if there is no reading (its a dummy light)
jwill8957
Jan 5, 2013 02:04 PM
martink01
Electrical Systems/Wiring
Aug 10, 2010 09:48 PM
Mikalee1964
Sep 8, 2006 09:25 PM
F 2fifter with a 4 sixter
26
Dec 26, 2003 01:26 AM
