rolled truck decisions
Old May 26, 2012 | 04:24 PM
Fsj 7.3 guy's Avatar
Fsj 7.3 guy
Ok here's the deal I have a rolled 2000 f350 extended cab long box with a 7.3 and a 2002 the same only short box. The 02 smokes bad until the turbo spools up then cleans up. I believe it may be the injector module but I don't know for sure. I need to find out where the module is located and if the 00 and the 02 modules will be compatible. Any other ideas on diagnostics will be welcome since I don't have much experience with diesel engines I am however well experienced with gas engines and turbo systems and have built some nice rides so I am not a noob when it comes to wrenching. My original plan was to swap engines between the trucks but now that I have the 02 running I think it might be better to see if is fixable. Ps I'm not looking to part out anything till I get the 02 on the road since I might just make the 00 a bush buggy. I should also note that the 02 is new to me and it also has a cold start issue where I have to hit the glow plugs twice then crank the engine over a few seconds then hit the glow plugs a couple more times floor it and crank it and it usually starts after that but I think its tied in with the injector module problem. Thanks for the help in advance.
Old May 28, 2012 | 12:37 AM
Fsj 7.3 guy
Hmm nobody has any ideas?
Old May 28, 2012 | 01:13 AM
wallz's Avatar
wallz
Jump into the specific 7.3 forum and someone will jump all over it with suggestions.
Old May 28, 2012 | 01:20 AM
Fsj 7.3 guy
Thanks wallz probly a good idea I wasn't sure wich category would be better since both apply. Any mod care to move this over to 7.3 so I don't double post that would be great thanks.
Old May 28, 2012 | 07:23 AM
Tom's Avatar
Tom
Moved to the 7.3L forum!
Old May 28, 2012 | 02:57 PM
hammer65's Avatar
hammer65
I can't help, but here is a bump.
Old May 28, 2012 | 07:33 PM
F350-6's Avatar
F350-6
Welcome to FTE. How long have you had the 02? Have you changed the oil yet? I doubt it's the IDM (injector driver module), but it's tucked up above the driver side front wheel well. Drop the fender liner and the IDM is hidden up in there.
For the cold start issue, keep in mind that the glow plug light on the dash has nothing to do with the time the glow plugs are actually on. Instead of cycling the key so many times, what happens if you just turn the key and leave it in the on position for 30 seconds? (the glow plugs will likely try to stay on the entire time). The most likely culprit would be a bad GPR (glow plug relay). Take a screwdriver and short it across the 2 large posts for 30 seconds and then get in and start the truck like it was a gasser (don't wait on the glow plug light). See if that makes a difference.
Picture of GPR for reference
Old May 28, 2012 | 08:10 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
It sounds like you have a bad injector or two.
The module you're referring to is called the IDM or Injector Driver Module. Here's how to get to it: 99-2003 7.3l idm (injector drive module) location - YouTube
An old trick to find a bad injector:
-Pull the intercooler hoses for both sides noting what clamp goes where. You will need and 11mm deep socket for this
-Pull the valve covers. You will need a 13 mm of 1/2 inch socket and wrench for this.
-Start the engine and allow the idle to smooth out. Carefully unplug each injector individually while listening to the truck idle. If when you unplug an injector, the idle doesn't change, you've found your bad injector.
Clay at Riffraff Diesel is the ONLY place I know of (believe me, I've checked) that offer Stock re-man injectors at a VERY reasonable price.
Riffraff Diesel: Stock Rebuilt Injectors
Anywhere else I've checked is incredibly proud of a used or rebuilt injector and doesn't let them got for anything less than $250 to $300. (no including the core charge).
Should it come down to you having to replace and injector or two, here are two good write ups on it:
https://www.ford-trucks.com/forums/4...rs-are-in.html
https://www.ford-trucks.com/forums/4...-injector.html
Since the truck may have been sitting and not received the love it should have from the PO, it sounds like you have failed glow plugs or a failed GPR (Glow Plug Relay).
Either of the above would cause hard cold starts as the engine has to rely on whatever cylinders have good glow plugs to help start the truck. If all 8 were good, we wouldn't be having this conversation.
Start by testing your GPR per Guzzle92's instructions: Welcome to guzzle's Stancor GPR replacement Mod Web Page
If it passes, move on to the glow plugs. They can be tested through the connector for the UVCH or Under Valve Cover Harness.
Some instructions on how to test both here: http://www.dfuser.com/Install%20Guid...ug%20Relay.pdf
If indeed your glow plugs need to be replaced. Do them all to save yourself a headache later, here's where to get them among any other parts for your Powerstroke needs: Riffraff Diesel: Motorcraft Glowplugs
The bottom line: Initially, you may end up having to spend some money on the '02 to get it running right and proper, but you won't regret it. I've had my 7.3 since it was new (had 50 miles on it) for almost 11 years and 342,000 miles. It's never left me on the side of the road and continues to perform flawlessly!
Stick with us here on FTE and we'll help you get that truck running right!
Old May 28, 2012 | 09:33 PM
Fsj 7.3 guy
Still looking for help on this issue. I have another question aswell. Would it be better to swap cabs or swap engines. I am pretty sure the frame is still straight on the rolled truck but I have not had it measured since there is no point untill I know for sure the best rout to take with this project.
Old May 28, 2012 | 09:53 PM
Fsj 7.3 guy
Thank you for the great information sorry it takes me so long to write messages but I am working from my phone. To answer the question of how long I have had the 02 about 2 weeks and no I have not changed the oil in it because I know the engine in the 00 is in awesome shape and had it for almost a year (over 60 000km) and have had to do nothing except change oil and filters on it. This is why I have absolutely no hesitation in swapping engines or reusing the old frame or engine. And although the 00 has not been mine since new I do know its history for the last 8 years.
Old May 29, 2012 | 10:54 AM
SteveH-CO's Avatar
SteveH-CO
I would fix the '02 and keep the '00 until another project comes along and use the engine in that. Swapping engines at this point seems premature.
Old May 29, 2012 | 11:12 AM
Tailgate77478's Avatar
Tailgate77478
As stated by F350 and Toreador, I think you'll be able to figure out your cold start issue. The comment about the new GPR is a good one, and is a cheap fix. You may need the glow plugs replaced as well, again, cheap and relatively easy.
It is possible your low pressure oil pump (LPOP) is leaking down, and needs to be replaced. Again cheap, a Melling LPOP is about $80, but the work is a little more...but doable if you have the right puller tool and someone who can help you as well.
Don't give up on that '02.
Maybe post where you live so someone from here can come help. A trick is to go to a general discussion forum or a "test" forum, and make a bunch of small posts so that your post count gets up over 25, so that people can see your location.
Welcome to FTE!
woodnthings's Avatar
woodnthings
You don't want to swap the cabs. The '02 has different wiring than the '00. They updated the trucks in '02 with digital dash, removal of the GEM, and a few other upgrades. All the fuses and diagrams are different. The '00 also has forged rods(most likely) where the '02 will have PMR's. Swap the engines if you go that route.
Old May 31, 2012 | 02:23 PM
Fsj 7.3 guy
I live in fort st john bc just to let you know and if there is anybody who wants to lend a hand of course they are more than welcome to do so they might even get a couple beers lol.
Old May 31, 2012 | 02:37 PM
Brother Les's Avatar
Brother Les
It should be warm enough that you would not even need your Glow Plugs. You may need to look for an other problem for you 'cold start'..... Weak fuel pump and weak fuel pressure? Do you have good batteries? If the batt voltage drops below 10.5v, then these trucks become harder to start.
