Keyless Entry - door codes ?
Old May 5, 2003 | 11:44 AM
Papoverse's Avatar
Papoverse
Smile Keyless Entry - door codes ?
Hi Everyone ! New member and first time post. Love this site quite informative. Anyway,
I hope somebody can lead me in the right direction.
I've had my Expy for two years now, since then
I've been trying to locate the codes to the keyless
door lock ? Without having to bring iit in to my
local dealer,,,,is there a way to come up with the
codes ? I saw a post referring to the jack storage
area for some clues but found nothing back there.
Thanks !
Julien
Old May 5, 2003 | 12:41 PM
ineedashot's Avatar
ineedashot
If you look under the dash, position your head in front of the brake pedal and look up. There is a black box with a white label that has the code printed, is a sequence of 5 numbers. You won't miss them...
When you type these numbers in the keypad, driver door will unlock, push 3/4 and the rest of the door will open...
Old May 5, 2003 | 01:57 PM
Papoverse's Avatar
Papoverse
Thanks will try that !
Old May 6, 2003 | 11:17 AM
02PSD4ME's Avatar
02PSD4ME
opps you forgot... than change it to something you can remember...
Old May 6, 2003 | 11:39 AM
Papoverse's Avatar
Papoverse
Thumbs up Keyless Entry - door codes ?
Again thanks "ineedashot" It took a few minutes
to figure which box under the dash it was. But after locating a black box close to the fire wall which had a decal with several numbers, I fiigured
I try the larger block of numbers (seriies of five as
you mentioned). I keyed the code in and it worked
like a charm !!!
NOw, I',m curious about that last post, how do you go about changing the code. ? Eitherway, I think I'll stay with the OEM set(they're in my head)
Thanks everybody !
Old May 15, 2003 | 12:16 PM
tweety03's Avatar
tweety03
I thought that even when you change the code to your own number that it does NOT override the factory code!??
Old May 15, 2003 | 12:29 PM
1999XLT's Avatar
1999XLT
Tweety, It does not Override the factory code. It adds another code to the entry. You then have two codes to enter your vehicle.
